Question about Ovens
Smeg oven SE37MFX5
My smeg oven is not working. It started when there was a popping sound in the oven followed by display lights flickering then no power. When switched on, the orange light does not work , and no didgital display. I replaced the oven element which was the cause and the oven bulb. However unsure as to what to replace with the digital display and orange lights not working.
By the sounds of it, there must have been a power surge to knock out the digitla display and orange light. Is there a fuse or does the circuit board need replacing?
Further starting the oven again after replacing element and bulb, no light goes, one of the fans work but the second centralised fan to circulate the heat does not work.
Any suggestion as to how to get the oven working again?
4 Suggested Answers
  • 1462 Answers
SOURCE: SMEG SUK62 MFX
check stat is not open circuit and check selector switch not damaged
Posted on Oct 18, 2008
  • 417 Answers
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
Posted on Oct 19, 2008
  • 86 Answers
SOURCE: NEED USER MANUAL FOR SMEG SE375MFX5
SMEG SE-375MFX5 Owner Manual
Posted on Feb 09, 2009
Smeg SD012 top oven failed
Is the clock set to auto and not manual? Is the clock display flashing? If so then set to manual, this should do the trick
Jan 17, 2014 | Smeg Ovens
Smeg linear oven is displaying sho (showroom mode) and will not heat up. I have held down function knob for 5 seconds which clears SHO from display but within seconds it comes back. Any ideas
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 28, 2013 | Smeg Linear Pyrolitic Single Oven Electric
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Oven will not switch on
If there is an A only on the clock(no other digits) your clock has failed. Either replace , or can be bypassed. Oven won't work without clock set.
Dec 14, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg cooker 8 function model
Hi.
Sounds like you have a faulty thermostat, the contacts could be sticking.
New stat would seem to be called for.
Nov 21, 2008 | Smeg SE399X/5 Stainless Steel Electric...
SMEG SUK62 MFX
Oct 18, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
REQUIRE AN INSTRUCTION MANUAL FOR A SMEGG SE378 MFX5 OVEN
You can get instruction manuals for all smeg products by following this link http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Dec 06, 2007 | Smeg Ovens
Smeg oven diplaying an "A" in display
I have had the same problem today - trying to change to day light saving time - can you help me too if you find out.
Sep 25, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
