Question about LG RU-23LZ50C 23 in. HD-Ready LCD Television
Not operating SIZE button.
Hello, I have LG TV and my grandfather did something with remote control, and now televisor view is contracted, and SIZE button don't help me. Does anyone have solutions how to solve this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Try going to menu, find video setting and play with different settings until it goes back normal.
Posted on Oct 20, 2008
E control remoto jisco jrc-1 es compatible con un televisor lg
Likely yes, if you can input code then it will work, here is a list of LG TV remote codes, you might have to try all of them.
LG 0037 0056 0442 0001 0370 1178 0002 0009 0377 0032 0556 0003 0217 0019 0030 0714 0038 0216 0431 0290 0163 0644 0060 0178 0108 0606 0109 0700 1934 1926 0698 0715 0823
Remote Control Programming Codes
Feb 09, 2017 | LG Televison & Video
Tengo un control remoto universal Polar 9045699 y perdi la hoja de codigos y tengo un televisor LG. Alguien que me ayude con los codigos para Tv LG Flatron. Gracias de Antemano.
hola perdi el catalogo de mi control universal polar 9074996 y no tengo ni idea cuales seran los codigos, serian tan amables en ayudarme por favor
Jul 30, 2013 | Televison & Video
The televisor it doesn't start with the remote control and the lateral buttons
Check to see that the remote control batteries are properly installed. They need to point in the direction indicated on the remote. Of course, the batteries need to be good! Perhaps the remote sensing eye on the TV is blocked. Be sure nothing is in front of the TV to block the sensing eye.
Sep 25, 2012 | JVC LT-46AM73 46 in. LCD HDTV
Hello I'm finally back again I got a customers LG tv Model #37lg30 it does not respond to the remote the buttons on then side alow us to operate the tv I tried the remote on another
Check on the back of the TV to see if you have a "remote in" port. It will look the same as a 3.5mm headphone jack. Unplug the TV and plug a pair of headphone into the port and then remove it. Do this several times to breakup any debris that may have gotten into it or corrosion that may have occurred in the port. If something is in the port it will disable the standard remote sensor on the TV.
Mar 23, 2012 | LG 37LG30 37 in. LCD HDTV
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
LG 42PX4MVH remote control does not operate the TV, it seems that it needs to be re-synchronised, how do I do it? The batteries was replaced yesterday and the lights on the remote control flashes and...
Hello
If you are using its original remote control handset with this set, replacing batteries will poise no problem at all. If remote control does not works properly check the following.
Check to see if there is any object between the TV and the remote control
causing obstruction.
Are batteries installed with correct polarity (+ to +, - to -)?
Correct remote operating mode set: TV, VCR etc.?
The light at its side
Illuminates the remote control
buttons of selected mode.
OK.
Apr 26, 2011 | LG 42PX5D 42 in. Plasma HDTV
My plasma has the screen distorted after my son pressed something on the remote. It is like the picture is three times the size.
Ur tv are to much zooming in mode.Look on the remote control for a button that said like VIEW MODE,ZOOMING,PICTURE SIZES.Press one of these buttons to changes ur tv picture sizes.
Feb 26, 2011 | LG 50PG20 50 in. Plasma HDTV
Como programar la segunda television
Hola mi nombre es Mayra Diaz con DISH Nerwork con mucho gusto le puedo ayudar con su televisor numero dos. Primero tenemos que verificar que el cable que viene de la pared este localizado detr?s de su televisor. Segundo paso necesitamos verificar que el televisor este en el canal 60 o el canal 73. Si no funcionan estos pasos por favor escribanos.
Feb 18, 2011 | DISH Network IR Remote Control
How do i reduce the picture size on a LG 48 it was changed and now i cannot read the kyrons, the picture is larger that the TV [make sense?] thank you
Look for the button on ur remote,that said VIEW MODE or P.SIZE.Push one of those button either one on ur tv remote.Than pick the size of the picture,that fit ur screen.
Oct 12, 2010 | LG Televison & Video
Codigos para televisor LG Haier y Coby
hola mi nombre es henrys hernandez pero necesito los codigos para un tv plasma coby sin mas gracias mi correo es henrys.hernandez7@gmail.com
Jul 28, 2010 | EverFocus RE100H Remote Control
LG RU-23LZ50C 23 in. HD-Ready LCD Television Logo
Computer Repairing
Computer Repairing
