Question about Sony KP-61V85 61" Rear Projection Television
What is a convergence problem?
My sony kp61v80 just started having problems with the color blue. A blue "ghosting" seems to exist all the time. It also seems to get progressively worse on the right side of screen. It is a very noticeable problem, especially with text on the screen. This exists no matter what video source I use: satellite, DVD, videogame. This was a sudden onset problem. It worked fine yesterday. Is this a so-called "convergence" problem? If so, what is the solution? I have pressed the "flash focus" button on the TV itself. This seems to do some sort of alignment test, but it does not help the problem. If it is a "convergence problem, what is the solution, and what is a fair price to pay for the repair? In other words, is it so much that the cost so much that it puts me into a repair/replace quandry? This TV is only about 5 or 6 years old. If the problem is serviceable, are there more than 1 convergence parts to be replaced at the same time, so that I am not faced with the same problem (different color) a year from now.
    President:
  • 3,130 Answers
Your problemo could be a so called convergence problem BUT it could also be a problem with the blkue tube or the focus block as well. If its convergence then YES for sure have the other ic(s) replaced at bthe same time cause if ones bad for sure the others going to have a problemo shortly. Now to the replacement?? I would say a fair price range to pay for a repair such as this would be about 300 to 400 buckeroons. This would also include Im hoping the repai, alighnment and cleaning of the sets optics. Alwat remeber theres alot of HI Voltage inside these sets even if they are unplugged, so be carefull!!!!!!!!!! Good Luck
Posted on Jun 27, 2006
Sony KP-51WS520 51" Rear Projection Colors have been over saturated for awhile...selecting vivid seemed to help. But now I am getting a ghosting effect on most words, always to the right.If I go to...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 09, 2010 | Sony KP-51WS520 51" Rear Projection...
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
Ghost on the screen, blue in color
Did you check the six 3.15 amp pico fuses on the D board in line with the resistors and the two 5 amp picos on the G board? Usually one or more of the Picos will blow especially on the G board
Nov 24, 2009 | Sony KP-46WT500 46" Rear Projection...
Red and blue ghosting,
*Screen Looks 3-D
*Colors wont align
Problem #2
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com.
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 02, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
How to get rid of blue ghosting
*Screen Looks 3-D
*Colors wont align
Problem #2
Oct 26, 2008 | Samsung HCL4715W 47" Rear Projection...
KP-53S65 Blue Ghosting
*Screen Looks 3-D
*Colors wont align
Problem #2
Aug 11, 2008 | Sony KP-53S65 53" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
93 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
