To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
Disconnect the drill from the power source and remove the chuck key.
Turn the drill over so that the chuck is facing upwards.
Locate the spindle lock button on the side of the chuck.
Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
Once the chuck is loosened, you can remove it from the spindle by pulling it off.
To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
Take the clamp apart by removing the spiral ring that holds the collar on and then remove the pin. Make sure you write down how to put it back together! Once you remove the pin everything else will come off easily! diagram the whole thing as you go!
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
usually you would remove the chuck first under my name in the profile section is the tip for chuck removal, it is a standard thread probably 1/2-13. As far as the gears go try the site Milwaukeetool.com and type in your model number for a parts explosion. Let me know if I can help further
