Question about HP LaserJet 1020 Printer
Paper out jam in hp laserjet 1020
Have Laser Jet 1020. It works for 2 years without any remark. But Now due to change of teflon sheet, my printer is giving only one print when I run the system, second print is not taken and showing the problem that paper jam, but there is no paper jam, Please give me solution.
  • 435 Answers
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Posted on Oct 20, 2008
How can fix this error. i seen this "the hp laser jet 1018 has the front cover door open or the toner cartridge is missing"
Hello !!
For tha particular error you are facing, here is the reason. These printers have a switch that triggers an interrupt when the toner door is closed. Usually there is an arm on the door that pushes the switch. It is quite sensitive and delicate. Then sometimes there is a tab on the printer's toner and if that breaks off then that error will be generated.
But in your case as you have not removed or inserted the toner, I think option 1 is applicable to you.
Now, if this printer is in warranty you should send it to HP for Free repair/replacement.
and chek BLOW links too for paper jam and cleaning
Paper jam Message Displays for HP LaserJet 1018 1018s 1020 and 1020 Plus... Cleaning the Printer
Dec 23, 2014 | HP LaserJet 1018 Laser Printer -...
Paper jam in hp laser Jet 1020 printer
Sir/Madam
I suggest You Please Watch Below YouTube Link URL To Fix Your HP Printer Error:
http://www.youtube.com/watch?v=M4BJ-0A029M
Or
In case You still need Online Support For Hp Printer Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet 1020 Printer
Printer hp 1020 in it when we print command of more then two paper the second paper jam (half inside and half out paper does not reach to Teflon part section . single paper printing is OK no pro....
Clean the Paper Feed Rollers with wet cloth.Then go to start-ControlPanel-Printers-select Hp1020 printer-properties-features-change the Paper Type as PLAIN PAPER.
May 23, 2011 | HP LaserJet 1020 Printer
Paper jam problem HP LaserJet 1020 Printer
there is a lever in the top vover to close the cover sensor, and it may be broken or bad seated
Mar 19, 2010 | HP LaserJet 1020 Printer
How to replace teflon sheet in laser printer
Nov 03, 2009 | HP LaserJet 1020 Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
Have paper out jam
hi,
maybe your separation pad is worn out that's why it can't pick up paper which causing the paper jam...
rey
Oct 21, 2008 | HP LaserJet 1020 Printer
HP Laser Jet 1020
It was the teflon sheet problem just change it
it costs around 6$
Thank u
Take care
bye
Apr 07, 2008 | HP LaserJet 1020 Printer
Printer problem in hp laser jet printer 1020
Problem is you have paper jam!!! Seek for the paper inside the printer, pull out cartridge!!! when you do that, turn off printer and disconnect power cable for 1min. Pull back the cable, turn printer ON!!!
good luck!!!
Jan 29, 2008 | HP LaserJet 1020 Printer
Hp laser jet 1020 paper jam and not printing... half paper inside of printer
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Dec 27, 2007 | HP LaserJet 1020 Printer
HP LaserJet 1020 Printer Logo
1,072 people viewed this question
Ben Johnson
