Question about Microsoft Windows XP Home Edition
Skype test says my mike is mute? what to do
I got a new mother board and all things have to be reset I'm new and of the grey power my skype worked ok before with chats to germany
  • rosieop Oct 20, 2008
    yes i think i clicked something and it works ok
I have a Web cam and after ages of trying I have now got pictures to and fro with others but NO SOUND! It is a Deluxe Hercules Version 1.4
Posted on Dec 11, 2008
    Master:
  • 538 Answers
Ok..we can make this work...can you open your control panel and then audio settings? check that first.
Posted on Oct 20, 2008
  • A Womans Computer Man
    A Womans Computer Man Oct 20, 2008
    see my direct ask me for more information..patrick who specializes in those of the grey power..
    congratulations..remember that i specialize in the grey power set..
Sony projector NO power/standby led. Was working fine recently, bulb replaced less than 500 hours ago.
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
it is a little hard to test them. any help ,Pls contact me
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 16, 2014 | Sony VPL-ES1 Multimedia Projector
My T6216 Emachine stopped working. None of the
Even if those things power up doesn't mean your PSU is still good.
In particular the PSU in eMachines are known to be cheap/bad and one of the first things to go out.
If you have access to one try another ATX power supply.
You don't have to remove the old one just to test.
1) Unplug the existing PSU power cable from the back.
2) Remove all it's connections (MB, drives, etc).
3) Plug the other PSU in with just the two MB connections (the main, and 12v one), skipping any drives for now.
It's probably ok if the test one is not touching, but I like to put the PC on the side with the test PSU setting on top where the original one is making sure it has good contact with the case to make sure it's grounded.
4) Now plug the AC into the test PSU and power it up.
If it still dosn't power up it's probably MB, or CPU.
You could also unplug it again (you always want to unplug the PSU when doing anything, the power is always on), and try removing any add on cards (like your wireless card), and try again.
If it does power up (you get a POST screen), unplug PSU again, now plug-in drives, then AC back and see if it will boot up.
Jul 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
I HAVE TROUBLE HEARING MY CONTACT
Hello there!
Dear Esther M Shane, if you are having problems with hearing other skype contacts, please do next :
Check your output(speaker) volume, put it on maximal,
talk with your contact, advise him/her to volume up their output, or to possibly change their quality due to equivalent of your chat.
Its not really your fault if you cant heart their output very well, those people should check for problems with their imputs, ofcourse if you done all checkings I have told at the text up there.
I wish you good luck and a lot of quality usage of skype!
Sincerely
Aleksandar Adzic
Apr 17, 2010 | Skype IM
EPoX EP-9NDA3J Motherboard do not work. There no any display information on monitor, no any beep sound, Power supply -is ok, fans are working ok, self-test indicate "FF" at once (not testing). Reset...
u must replace ur mother board coz there is problem of power section of motherboard. if u tring to solve problem on same mother board . processor may be also going dead so avoid R&D and plz replace motherboard otherwise u must send ur motherboard at my service centre in india . u can mail me at my mail id amit_arya8382@yahoo.com . enjoy good luck plz vote on my comments
Sep 02, 2009 | EPoX EP-9NDA3J Motherboard
My second Computer windows Xp Prof. problem with "MICROPHONE".
go into your Control Panel, find and double click on Sounds and Devices- click on the Voice tab, under Voice recording - change the Default device: to the device you are using. this is not a monther board problem, its software problem, as long as you are sure that the mic is working
Aug 14, 2009 | Microsoft Windows XP Professional SP2 Full...
My microphone on my acer aspire one isnt working
I had the same issue. This is what I found. It seems the Realtek audio and the Microsoft volume drivers are conflicting with each other. If you look at the bottom right (next to clock) you should see the usual grey speaker icon (Microsoft Master Volume controller) and you may also see a reddish speaker (Realtek audio) icon. This should indicate that both are controlling your audio.
If you click [start] - [run], type: msconfig and click [ok]. Click on [startup] tab at top. Look under startup item and uncheck: RTHDCPL then [apply], [ok] and restart your netbook. After it reboots the only audio icon that should appear is the grey speaker (microsoft master volume controller). Your mic should work now. Go to sound recorder and test. You may also need to upgrade to the lasted audio driver from the acer site but try shutting down Realtek first.
Dec 25, 2008 | Acer Aspire One AOA150-1570 Notebook PC
Gigaware mike cannot unmute for skype
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Dec 25, 2008 | Computers & Internet
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Why did my computer mother board burn out,after only having the comouter 5 mothes from brand new.
if you have a waranty and it is still good i would use it !!!! motherboards will burnout because of power surges water getting spilled on it if it gets knocked around it can go out like mine did shorts in the wiring or board itself there are many different things that can make a board (croak) please keep me posted ok best regards mike
Aug 23, 2008 | Compaq Computers & Internet
Microsoft Windows XP Home Edition Logo
178 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
