Question about Fuji FinePix F700 Digital Camera
When battery is changed date and image size need resetting
Every battery change requires date/time reset and image reverts to 1MB
  • nickf700 Dec 22, 2008
    I have the same problem, how do you change this?
  • 320 Answers
These units have a small internal battery, similar to a coin cell used in hearing aids, except that it has solder tabs so it can be mounted to the pcbd. You need the internal battery changed.
Posted on Oct 20, 2008
  • Tomislav Hocenski
    Tomislav Hocenski Jul 05, 2017
    hi! can you somen tell me can I change internal btery on finepix f650 and how ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Internal battery or capacitor may be bad and not holding charge to keep settings.
Sodering bios to reset password
Remove the coin cell battery on the motherboard for a few minutes, long enough for the bios to reset. Reinstall the battery, boot the PC and reset the date and time.
Nov 15, 2015 | Toshiba Satellite Computers & Internet
My D 630 Win 7 laptop periodically resets time & date to the last manual setting? Is there a fix?
Not too difficult if your a member of the computer Dr mobile pc Dr's in black n white volkswagons. But it is the battery on the mother board
it should be 3.0 volt lithium watch battery 2016. Battery is dying an not holding its tsr programs on the cpu an reseting to defualt cmos
changing battery's information onyoutube based on your pc cabinet and its model and serial number. They'll play start to finish end user information on issues listed by steps
Aug 26, 2014 | Dell Computers & Internet
My Gateway laptop won't boot up it keeps saying "failure configuring Windows updates reverting changes" Do not turn off your computer
Make sure the Date & Time are set correctly on your machine. That can interfere with Windows Update. If your computer has the wrong date/time, you need a new cmos battery (available anywhere). Then, If you are running Windows 7, try the "Windows Update - Reset" options here... http://www.sevenforums.com/tutorials/91738-windows-update-reset.html?filter
Jul 16, 2014 | Computers & Internet
Dect 6.0 corded telephone
I would take the battery out then put it back in. It should reset. But you will need to put all the other things like time/date etc...
Mar 16, 2014 | GE Lands Phones
Problem with BIOS. Cannot change system date.
Put all default setting on CMOS setup and then set the date by checking that the replaced one battery is energetic enough to meet the system requirement. I mean to say having 3V as it should have.
best of luck!
Mar 11, 2012 | ASUS Motherboard P8P67 PRO REV 31 Core...
My date and clock keep reverting to 2001 every time I close and reopen my computer?
when you first power up the machine, go into the bios settings and check the clock in there, if this is wrong, it will reset your windows system time. Reset to the proper time and then when you go into windows your time should be correct, if not, correct it and restart. If the problem persists and the bios time resets itself, you will need to change your bios battery. This is a flat cell type battery, usually a cr2032. They are cheap and easy to replace and should sort your problem.
Hope this is helpful.
May 06, 2011 | Computers & Internet
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
  1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
  2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
  3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
    Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
  4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
Date resets back to 2001 after being powered off
Try changing the time and date in the BIOS and then save the changes and exit. Then turn the computer off.
Wait a few minutes then turn the computer back on and if the date resets back to 2001 then that means the battery on the motherboard is bad and would need to be replaced cause that means the BIOS isn't keeping information in memory.
The battery you would need is a cr2032 battery. Here is an enlarged image of the battery Im talking about:
http://media.digikey.com/photos/Panasonic%20Photos/CR2032.jpg
Aug 08, 2009 | HP Computers & Internet
Nokia mobile phone model 6101.
Try reset your phone to its factory settings!
Go SETTINGS..... RESET FACTORY SETTINGS......then 12345 for the sec code.
if nothing happens, then bring your phone to service shop then let them solve the fault. im think there is a need to replash the firmware.Is this advice/solution helpful to you? You can send me email at st_nardz@yahoo.com for my further assistance. Kindly rate this up! Thank you very much..
Oct 16, 2008 | Nokia 6101 Cellular Phone
Hi I have a new
.The settings will be saved if you entered and give OK
Once the main battery is removed for an extended period of time, the time and date settings will be reset to the default setting, and an icon will start flashing in your LCD monitor to notify you that the time and date has been reset.
Through the eye view finder you can see the settings detail.
Apr 04, 2008 | Nikon D40x Digital Camera
Fuji FinePix F700 Digital Camera Logo
418 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
