Question about Miele 24 in. G656SCi Plus SS Built-in Dishwasher
Miele G520 dishwasher
Does anybody know if the thermostat is normally open or normally closed?
  • jg129 Oct 20, 2008
    I replaced the original thermostat with one that is NO, so it closes the circuit when temperature is reached. Not only that the DW doesn't heat up, the timer doesn't advance, and at some point it lets water in and then pumps it out endlessly. Doen anybody have a proper solution to this messy problem?
    Thank you in advance.
    President:
  • 1,462 Answers
Goes open circuit when temp is reached.
if you are getting no heat, then look at the heater relay
Posted on Oct 20, 2008
We have a Miele G 870 SC dishwasher. The soap dispenser always opens properly to dispense soap if we run the Economy cycle, but it always stays closed if we run a Normal or Intensive cycle.
I would certainly check with the repairman and have it checked. It is possible that a connection may have been missed since the new dispenser was installed.
Oct 02, 2017 | Miele Dishwashers
Is this normal for Miele dishwasher? - some water left below filter and not everything dry after cycle
Plastic items do not get dry because they do not get as hot as glassware. A lot of moisture inside is do to the evaporation of water on the dishes during the dry cycle. Some water remains in the dishwasher because it is impossible to pump all of it out. There is nothing wrong with your dishwasher.
Oct 31, 2015 | Miele Dishwashers
I have a Miele G7883 dishwasher displaying an error code of F4E. Anybody know what this means?
towilson -- Miele G 7883 operating instruction guide can be downloaded (no-cost) as PDF. Check this manual's FAQ for error "F" codes. If data link is being used, check connectivity. If you have more questions, please contact qualified service technician. -- SWT
Aug 04, 2010 | Miele Dishwashers
I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
Aug 24, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
Miele G868 built-in dishwasher water inlet problem
Pull of the program knob. Then you should find a water-intake-time-selector to the right of the axis. Take a screwdriver and turn it slightly counter clockwise one click to increase the time and vice versa.
Here's the manual:
http://www.miele.com/manuals_pdf/Residential/Dishwashers/English_manuals/Operating_Instructions/G870_us.pdf
Feb 12, 2009 | Miele 24 in. G870 Built-in Dishwasher
Switch Postions SHU43C02
you need to use a tester and check for yourself for whatever you are looking for.
May 26, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
G661 SC
It's called the water intake. They usually dont give too much trouble. Can you give more info on the symptoms please?
Any lights flashing on the machine? If so which ones?
Is any water at all coming in? or is the machine totally dry?
Jan 04, 2008 | Miele 24 in. G656SCi Plus SS Built-in...
My Miele dishwasher is not heating the water.
You would need to look at the wireing diagram and find out if there is any thermostats that I'm sure there are. You would need to find out if they are working properly.
Jul 13, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G656SCi Plus SS Built-in Dishwasher Logo
792 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
