Question about Toshiba 56HM195 56" Projection HDTV
Redish distorted cable picture until I change input source and then go back to cable input
I have a brand new toshiba 56hm195 and all pictures look great and tv works wonderful, except i'm having an issue when i turn the set on. if i turn the tv on when it's connected to the cable box, the picture is all redish and bluish and totally distorted. it's like 2 smaller images of the same channel distorted together with small scanlines. i have to then change the input source to another source and then go back to the cable source and it's fixed every time. it doesn't happen every time i turn the tv on. it's about 60% of the time. it's highly annoying. cable company has replaced the box but doesn't seem to know what it is. i can't figure out if it's the tv, the cable box, the signal, the cables, etc.? the dvd player and other input sources all work perfectly, so it's just with the cable box. anyone see this before??
  • 1 more comment
  • Anonymous Nov 19, 2007
    I have the exact same problem,did you ever fix your set?Had box changed twice,replaced cables,had signal board replaced.Problem is now everytime I turn the tv on.
  • Anonymous Dec 15, 2007
    I have the 56hm195 also (one year old). Only happens on HD input. Directv is coming out to swap their box, so I hope that works better. If not, it must be the TV.
  • s1mo Mar 26, 2008
    Have the same problem occasionally, when turn on tv w/ cable as source input. Not sure what it is, but if we switch source to video1 and then back to cable it clears up immediately.
I have direct TV and I have the same problem also. It happens about 1 ot of 8 times. All I do is turn off the satellite receiver for a few seconds and turn it back on while the TV is left on. It works everytime. Don't drive yourself crazy with repairs and the like. It is just one of those things.
Posted on Jun 22, 2008
  • 1,476 Answers
When you say brand new, just how new is it? Your unit could be covered by the warranty. Certainly something worth checking into. If it works fine on all inputs except cable and the cable box has been changed your problem is probably in the digital receiver in the TV. This is something you will need a qualified repair tech to look at but should not be an expensive fix (compared to the cost of the unit). First make sure it is not covered under warranty. Free is still better than having to pay! Good luck.
Posted on Jul 12, 2006
I have a toshiba 50 hdx 82 it has a distorted picture with pink and green halos
The Scaler Digital board is going out in your set. You will need to contact your local toshiba service center
Aug 13, 2012 | Toshiba 56HM195 56" Projection HDTV
Toshiba 56hm195 tv picture freezes
Check to see if using HDMI input and if so try component input and also advise me if using box of some sort.
Mar 12, 2012 | Toshiba TW56X81 56" Rear Projection...
Main source should be on tuner and the color is off, what should I do? The main picture source has been set on Tuner forever, but after having some cable repairs, the main picture source is now Component,...
If you want to change the input source to tuner, go to the remote, hit the source button until it says "tuner", then go to menu, page to the "picture" settings, and page through to color, to adjust the color, You might need to also go to color temps and adjust the picture to your tastes. Keep in mind, however, that whoever changed the setting for the source to component, may have altered the port for your input. You need to check the back of your TV and see. The inputs are clearly marked. If your source is via coaxial cable, the you will want tuner as your source. If, however, your input has been changed to the RCA ports, then you will want to keep it on component, and just change your picture settings. Hope this helps, good luck.
Aug 08, 2010 | Olevia LT37HVS 37 in. LCD HDTV
My 57" Toshiba projection TV recently started having picture problems. The picture is distorted and wavy. The picture on the PIP screen is fine. is this a common problem and is it fixable?
First bypass the cable box and hook the tv directly to the cable to see if the problem goes away. if the problem persists you possibly have a bad input board.
Mar 13, 2010 | Toshiba 57HDX82 57" Rear Projection HDTV
Picture distorted
this a problem with the motherboard. not the lamp.
Feb 05, 2009 | Toshiba 56HM195 56" Projection HDTV
Toshiba HDTV DLP
this is the conversion chips and probably some resistors too
this is a common repair for all projection tv's , it cost about $400 to have a tech come out to do the repair
Oct 26, 2008 | Toshiba 56HM195 56" Projection HDTV
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
56HM195 Light Engine Troubleshooting
you should make sure that the onscreen menus are effected by the problem if they look OK and just the video bihind them is distorted the problem is in the digital video or what Toshiba calls the seine module. Probably not though it sounds like an engine. PTS electronics rebuilds some engines however most Toshiba engines are relatively reasonable.
Jun 07, 2007 | Toshiba 56HM195 56" Projection HDTV
Toshiba 56HM195 56" Projection HDTV Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
