I bought a remote control (suppose d to be an original) but it either doesn,t work or the monitor isn,t working. Any suggestions please
SOURCE: CAN'T TURN ON MY PHILIPS 42FD9925/01 SCREEN, ALWAYS IN STANDBAY
You need to have the correct code for this TV without it it won't turn on, I have a Direct TV remote that will do it as well as the remote that came with it so contact philips for the 3 digit key for that model. 0307
SOURCE: Picture is not centered on monitor leaving a 2 1/2" black border on Philips LCD
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
SOURCE: Remotes no longer work
I had this exact same problem. After a week or so it started responding to the remote control again. Then after a couple of days it stopped responding. This problem came and went for about a month, then one day the entire TV went dead. When I powered it on, the green light appeared for 2 seconds followed by a sequence of 6 flashing red lights that repeated. I brought my set in to a repair shop and they replaced the power supply board. That fixed the problem and now the TV powers up and responds to the remote control again. Total charge was $250. That was very disappointing for a $1,500 TV that was only 18 months old. I'm going to let Philips know how disappointed I am in their product!
SOURCE: philips TV 29pt3425 after a while switches off to
Ur power supply board,have burn capacitors,check for puff up caps,know how to solder?If not,no puff up caps,change the whole power supply board it somethings burning not notice, able to see in the power supply board.
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
