Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error WHEN I TURN ON THE CAMERA SHOWING LENS ERROR AND I AM UNABLE TO TAKE A PICTURE
  • diminom4 Nov 09, 2008
    does anyone know why this happens?  can this be fixed under a warranty?
  • 477 Answers
Sorry to hear you are having this issue. well the problem is your lens. the len motors have locked up and are stuck the lens needs replacement. repair run any where from 75.00 and up in most cases.i repair these all of the time.let me know if i can help out any further.
Posted on Nov 05, 2008
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I Have a Canon powershot A410 and I cant get it to work anymore. The lense will not open and it beeps at me and then E18 shows up on the bottome left hand side of the screen. I can still down load all my...
The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover.
This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution
Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area:
  • Hold the camera so that your fingers do not touch the lens unit when you are shooting.
  • Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.
If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service
Oct 21, 2008 | Canon Cameras
Kodak EasyShare C533
When I turn on the camera. the lens will not extend. The screen
will not show anything but a message, " date & time are already
programmed". No menu item works. Pictures cannot be taken.
Apr 21, 2008 | Kodak EasyShare C663 Digital Camera
Quantary Tech-10 75-300mm use with Canon Rebel XTi
Hi all
On most lenses the way to test if your old lens works on a cannon digital to set the camera to AV then set the iris to the small setting ie F16/F22 then use the stopdown button.
Things that might happen
1 The lens will close down OK
2 The error 99 will show,will need are rechip if avaliable
3 Nothing happens, will need a rechip
Q.Why will it work inside but not outside.
A. Inside the camera needs light so the iris is full open, outside the lens needs to close down and if not compatible it is unable to close down. will need a rechip
Mar 12, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
E 18 problem
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
the E18 means the lens system has a problem. I had it with my S2 and sometimes it worked, sometimes not. Eventually it stopped working. The only solution was sending it to repair, they changed the lens system.
Best Regards
Nov 19, 2007 | Canon PowerShot S2 IS Digital Camera
Lens is stuck out
push up on the inner lens housing,
Dec 24, 2006 | Kodak EasyShare LS753 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
59 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
