Question about Packard Bell Easy One Silver 2120 Notebook
Back up problem
Hi Teflon2 here I have a packard bell and am trying to back a Sage Line 50 to a memory stick
  • teflon2 Oct 20, 2008
    have tried 2 memory sticks one of which was empty and logged the file but there was nothing in it
    Master:
  • 538 Answers
Ok..got it...well...we can certainly make that happen
how much is the memory stick
and how big is the file you are backing up?
Posted on Oct 20, 2008
Hi all I am gettig the following with my sage line 50 v7 'sage report says unable to connect to data sourc, check configuration' I then get a system error coded 2 Its on windows 98 Can anyone...
Try removing Microsoft.net framework 3.5 sp1 from add remove programmes has known conflict with sage. If this does not work then try removing the .net framwork 3.0
Oct 05, 2010 | Sage Instant Financial Suite v8.0 CD Win...
I have just upgraded to sage line 50 accounts professional, yet when i try to run it it tells me the data file could not be found.my data is held on another networked computer and i can see that the path...
Hi allweatherra
Sage 50 has a file called company. that holds the path to the sage Data. From version 2007 onwards this is held in c:\documents and settings\all users\application data\sage\accounts\2010(or whatever version you have)
Hope this helps
Feb 10, 2010 | Sage Instant Accounts 8.0 (013604ug)
Email Remittances - Report Designer Problem
Sage Line 50 Addpurch Utility
In Sage Line 50 V5, you could only produce remittances for the
supplier accounts you had set up in your Sage Line 50 program.
The information that appeared on your remittances was taken
from the supplier ledger.
In newer versions of Sage Line 50 you can produce remittances for suppliers
who do not have a corresponding supplier record. This allows
you to produce free-format cheques for one-off payments. To
enable you to produce free-format cheques, Sage Line 50 no
longer takes the information for remittances from the supplier
ledger. This means that you can produce remittances whether
there is a corresponding supplier record or not.
If you want to include additional information from your
supplier records on your remittances, for example bank sort
codes and account numbers, you should convert the layouts
you require using this utility.
Note: This utility is installed automatically into your
Sage Line 50 program directory when you install Sage
Line 50.
>> To use the Addpurch utility
1. Open a Command Prompt by clicking on to your Windows Start Button
selecting Run, then type the word COMMAND and click on to OK.
From the command prompt (for example, c:\windows\desktop>) type cd\ and
then press ENTER.
2. At the c:\> prompt type cd "Program Files\Sage Accounts\layouts"
and then press ENTER.
The prompt should now read c:\Program Files\Sage\Accounts\layouts
Note: If your Sage Line 50 program is installed in a different
directory replace the above instruction with your own directory
name. The directory path can be found within your program by
clicking on to Help and then About and choosing the System
Information Tab. Your layouts will be held on the same path
as your data directory.
3. Before you can convert your remittance layout you will
need to save this with a new filename. (maximum of 8 characters).
For example, to rename one of your existing layouts from
the c:\Program Files\Sage\Accounts\layouts prompt type:
copy remita4.sly newrema4.sly
Jul 07, 2009 | Sage Computers & Internet
I have tried to upgrade my Packard Bell Imedia 1559 to 4 gigs from 1 gig of factory installed memory. However, the machine will not accept memory from Kingston or Transcend in any combination, and although...
I have read many posts about the PB Imedia and problems trying to upgrade memory. Sounds like there are some motherboard issues with this PC . Some have reported success with mixing different memory types and speeds, but no real answers as to why.
You may have to check the voltage that powers the memory. Some memory sticks are rated at 1.8v , others use other voltages that will hang your system if mixed.
Check with the manufacturer for their recommendation.
Aug 07, 2008 | Packard Bell Computers & Internet
I need to open up my packard bell Ixtreme computer to insert memory .. how do I do it
Most documentation for a Packard Bell iXtreme would be here. To upgrade, repair or replace your memory, this document could detail the steps involve including opening the case.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 27, 2008 | Packard Bell Computers & Internet
Sage 50 Accounts 2008
I think I got the solution for you ...
User Name is Already in Use / Cannot Access YYY because XXX is logged in
Typically, when you get this message you will be asked if you want to remove the user from the request list. If you are asked this question, simply answer Yes and you'll be able to continue.
An alternative solution is to go in the data folder for your sage data (the default folder for versions prior to 14 is c:\program files\sage\accounts\accdata for v14, the folder is c:\documents and settings\all users\application data\sage\accounts\2008\company.000\accdata on XP and c:\programdata\sage\accounts\2008\company.000\accdata. In the data folder, you will find a file called QUEUE.DTA - delete the file and you should be able to get back into Line 50. If you have a multi user version of Line 50, you should only delete this file if you are sure that no-one else is using Line 50.
Mar 20, 2008 | Sage Instant Accounts 8.0 (013604ug)
Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Mar 08, 2008 | Computers & Internet
Pac Bell Easy Note Sc - boot problems
I think you should remove your Memory RAM at the back of the laptop and wipe the edges with a clean white sheet.you can locate this also using your manual
Put it back and lets notice the results..
But if the problem still exists then i think you should change the memory RAM with a good one..
Please let me get back to me and let me know the results..
Thanks
Jan 14, 2008 | Packard Bell Easy One Silver 2101 Notebook
Packard Bell Easy One Silver 2120 Notebook Logo
46 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
