Question about Philips E-Box FTR9965 DTV Receiver
Philips plasma won't turn on first time
I have a Philips plasma tv, model no.32fd9944/os1 and the reciever model no.is FTR9964. I'm having trouble getting the tv to turn on first time, either with the remote or directly using the buttons on the reciver. If I turn the power off and on again (on the screen and the reciver) eventually I can get the tv to power up, once its on there are no other problems. Also once it has been on for a while its possible to switch on and off with no problems. Philips repair service want £400 call out fee just to have a look at the tv (very cheeky), with labour and parts on top of that I may as well buy a new tv. Any suggestions? I would be very gratefull, or details of a company that will repair a Philips plasma for a reasonable price. Many thanks Neil Witney
  • 3 more comments
  • TORINTORIN Jul 31, 2008
    Has anyone tried to repair the 42 inch phillips by this method? I have the same problem.
  • jprcox Aug 20, 2008
    Wow this must be a common problem.
  • JC2751 Sep 07, 2008
    I Have same issue. TV wont start. Red light stays on but the green light wont light and TV wont start. Can someone explain step by step repair instruction ?
  • mjgramlich Nov 22, 2008
    I have a Philips plasma 42PF5321d/37 with the same problem green light comes on then red light flashes. will the same solution work on the 42"
    Thanks
    Mike
  • hoidaonguyen Mar 28, 2009
    where to buy those CAPS?
I have found this on a site and am in the proccess of trying to mend my plasma PF9964 as it started to take longer and longer until it stopped coming on. I've got the back off so I just need to un solder capacitors and replace. Here's the info I found. Bad power switch circuit General Comments If you have this problem with your Philips 32PF9964: When I switch the TV on, it appears as though it is going to start i.e the green light comes on, then after about 10 seconds it switches itself off and the standby light flashes red. It takes 10 /12 times before it starts and is getting worse. This is the solution: The problem is three caps. Change the cap 2663, 2664 both 100µ/25V and 2662,1000µ/25V. After you have changed them your TV will work again. You will find them easy if you unscrew the back on the plasma TV. Cheers, Mike
Posted on May 18, 2007
Hi Mike
I have exactly the same issue with my Phillips 42" - 42FD9954. Do you know if changing the same caps will help? Also where abouts they are located?
Cheers
Dino
Posted on Dec 24, 2007
I also have the same issue but on a 50" I cannot seem to find the caps can anyone point me in the right direction please?
Posted on Jun 29, 2010
I also have the same issue with a 42PF9431D. Can anyone fill me in as to whether this can be fixed similiarly and which caps to replace?
Will the caps have tell tale signs, like a puffy look?
Thanks,
David
Posted on Aug 13, 2008
  • gsman Nov 23, 2010
    did you ever get an answer ? I have the same prob.
    Thanx,
    Gman
    President:
  • 3,130 Answers
Contact the company info in your owners manual and give them hell, as to your trust in buying a set like this, and now no service support??? see what happens.
Posted on Jun 27, 2006
Hey Mike - thanks for that solution - works a treat
I had a tv engineer quote £280 for the repair - after reading your answer, I bought the 3 capacitors at 16p each, a soldering iron at £3.99 and some solder at £1.99.
About an hour later job done for less than a tenner!!
Posted on May 04, 2008
Our philips plasma's(32FD9944 / 69S) receiver box is not working. One of its IC has broken completely. So how can I find that IC's number. And if could not find its number then what is the second option
It will be difficult to get from open electronic spare part market; even if you did recognize its number; I'm sure. It will be best to contact the authorized service center for Philips. Gopakumar Gopalan Google
Dec 07, 2014 | Televison & Video
Manual for Philips FTR9964 reciever Match line Flat TV
http://www.manualslib.com/manual/129017/Philips-Ftr9964.html
Jul 29, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
Philips plasma tv model #42pw996217
Kevin I don"t know if you still have this problem? but if so I have a box and a remote. make a good offer and its yours.
R.Carter
469-337-4962
mrrcc2@yahoo.com
Feb 19, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
VGA 1 Detecting prob
Hi, it sounds like your driver file is missing or corrupt. If you have the orriginal driver disk Delte the driver and re-install it. If you don't have the disk, go to the manufacturers web site and download it. Regards mistyman
Sep 29, 2007 | Philips E-box FTR9964 Video Capture
Philips E-Box FTR9965 Blinking Red Standby Light
Hi, my TV is starting to develope a problem & I have traced it to the e box (mine is FTR9964). I had the screen repaired in January (would'nt start from cold) cost was £156 inc vat. Anyway this time its the ebox & since we are going digital next year I thought I would try & do away with the e box by using one of these http://www.js-technology.com/product_info.php?cPath=22&products_id=33&osCsid=c05e56ff6e909a4b42d53af48a5940ae I managed to buy one on eBay for £30, so fingers crossed it should be problem solved. Allan
Sep 11, 2007 | Philips E-Box FTR9965 DTV Receiver
Phillips 32FD9944/01s - sound but no screen
your set may have blown its y sus board and i know the x sus board is part of the plasma display panel either way your looking at a very expensive repair if your not warrantied
Jul 11, 2007 | Philips 32PF9964 32 in. Television
Only sound, no picture
turn the AC power off and on again, this worked several times
Jul 05, 2007 | Philips E-box FTR9964 Video Capture
Phillips FTR 9964 Blinking Green/Orange Indicator Light
PHILIPS 42 WILL NOT TURN ON,WITHE FTR9964 RECEIVER
TO BLINK ORANG /GREEN AFTER 40 SEC ORANAGE
May 23, 2007 | Philips E-Box FTR9965 DTV Receiver
Philips E-Box FTR9965 DTV Receiver Logo
6,292 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
