Washer dryer not heating up
Hello, my hotpoint wd 440 washer dryer does not wash hoy and also does not heat up in drying mode all other functions seem to operate, this leads me to believe its the heater element or part of. Im not sure where this is could you tell me where to look and also how to test it. thank you hotpoint washer dryer
  • 1,031 Answers
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Posted on Oct 20, 2008
  • Starnley Johnwells
    Starnley Johnwells Oct 20, 2008
    It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it
    check all you need to do here http://www.partselect.com/repair.aspx?ap... to determine the cause and how to test and replace it.hope this helps pls appreciate by rating it,thanks and Godbless
Dryer won't dry is there a filter which could be blocked
It could be the heater element if the machine is operational but not heating, or check the function buttons mine has a cool button that doesnt dry it just airs out laundry.
Jul 28, 2014 | LG WD-12126RD Front Load Washer / Dryer
Washed ok but when put on drying mode it made a loud grating noise
The drying fan is most likely clogged.
Take of the topp, then you will se the drying fan. Along with the heating system. There are several screws you have to undo on the heating canal. Then you should be able to clean the whole thing.
Sometimes the fan is broken, and need replacing.
This is not recomended if you dont know what you are doing!
Do a mistake with the overheating guards, heater position, wireing ect, and you could set the machine on fire the next time you use the dryer
May 14, 2014 | Hotpoint Washing Machines
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
Hotpoint aquarious wd 440 two years old tripping main board
A faulty heater in both a washing machine and dishwasher will trip swithes because they both cause an earth........the chances are you heater needs replacing......the reason its tripping after a short period is probably beacause the cycle doesnt start heating the water until after approx 15-20 mins depending on the cycle chosen
Mar 28, 2009 | Hotpoint Aquarius WD63 Front Load...
No heat in hotpoint dryer
Wire burned of heater on top of washer/open circuiy heater/thermal cut out open circuit
Oct 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint BWD129 1200 spin - unwanted drying cycles
This is more a workaround than a solution. When you choose the washing programme (say "D") and push the on/off button, two lights will flash, the "door locked" and the "drying" one. Now turn the "drying programme" button until the "drying" light stops flashing (in my case, this is true when I set the drying programme to 40°C). Then start the washing mashine.
Seems like the function of the drying programme button has shifted against the settings written on the button...don't ask me why! Of course, no guarantee but works for me. Please let me know if it does for you.
Oct 13, 2008 | QuietLine WD-9900 Front Load Washer /...
Zanussi WJD1667W not drying at all
I've got this machine, and all washer dryers tend to have two heating elements and it sounds to me that the heating element for the drying side of the machine's functions needs replacing. You could probably find a cheap element for the machine somewhere and get it fitted for a small sum.
Let me know if this rectifies your problem
WD Pro
Apr 24, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
WD440G. No heat in wash and dry.
I would first check exhust vent to make sure it's not clogged if so it will cause your heating sensor to shut down
Mar 28, 2008 | Hotpoint Aquarius WD63 Front Load...
both the 'wash' & the 'dryer' have their own heating elements, If the 'wash' completes its full cycle including 'spin', then I suspect this heat element is ok.Re the dryer, most likely the heat element circuit is 'open circuit' somewhere, could be  the element, thermal fuse, thermostat, or a wire burned out
Oct 23, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
248 people viewed this question
Top Washing Machines Experts
