Question about Canon Office Equipment & Supplies
I have a CanoScan D1250U2F Scanner and I do not have the Installination Disc, where can I Download this from?
  • Canon Master
  • 6,487 Answers
I can't found any drivers for the Scanner "CanonScan D1250U2F" on Windows 7 or on Mac X ???
drivers for canon canoscan D1250U2F......go to ... canon.ca
click on drivers for scanners and pick the model you want them for..
if you are in canada make sure that you click on drivers available in canada..
Good luck ...Jake
Jan 04, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
How do I install my canon d125OU2f with my Mac OS
make sure you have an installer compatible for mac os if not you can download on the internet. :)
May 30, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
I've totally lost my set up CD for my Canon Scanner.
http://software.canon-europe.com/products/0010565.asp
Presuming Vista OS Canoscan toolbox is the utility. Found in Canon support I might add.
Oct 17, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
Can't install CanoScan D1250U2F on my Windows Vista 64 computer
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 11, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
My canoscan D1250u2f doesn't even light up. The last time I used it the scan gear didn't find Twain. Now it does nothing. ?????
If it is USB and the device is not recognized in control panel, then there is no power to the system. The cool white fluorescent tubes used in scanners only last approximately one year. Other parts may last about the same time. It's time to change the scanner. It's too costly to change the power unit inside the scanner.
Jul 27, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
Not cd for d646u scanner
You can download from canon web page:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6622
Jan 12, 2009 | Canon CanoScan D1250U2F Flatbed Scanner
53 people viewed this question
old marine
old marine
