Question about Smeg WDI12 Front Load Washer / Dryer
Reset washing machine
You said you had to reset the washing machine to solve this - can you let us know how to do this, as we now have the same problem?
Many Thanks,
Locked light keeps flashing
Hi Ann, The link below could hold the answer... Please read and then click the link for more...... I hope this helps...CHEERS..
To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
If that did not solve the problem then it may be the "Lid Switch". Top loading washing machines that have a faulty lid switch will not turn the agitator and the spin cycle will not start. However on some washing machine models it will still agitate but not spin. To properly check this you must remove the lid switch.
How To Fix Washing Machine That Is Not Spinning or Draining
Apr 04, 2016 | Washing Machines
Whirlpool AWM 312 front loading washing machine motor does not spin.
Hi Sachinl, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
Apr 03, 2016 | Whirlpool Washing Machines
How do I fix my spin cycle the clothes are still really wet it spins but the clothes are still wet
Hi Russell, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components. (This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
Apr 03, 2016 | Washing Machines
Will not fill with water,and continually beeps
Hi Shirley, Before you check out the link below read how To perform the Master Reset, carefully unplug the washing machine from the power outlet and leave it unplugged for one minute. After one minute is up, plug the washer cord back into the wall. Next, open and close the door of the washing machine 6 times within 12 seconds to send a "reset" signal to all the components.(This is a common fix that many appliance repair mechanics use - it works on about 50% of all washing machines.) Once the reset has been completed set the washer to do a small load with no clothes in the washer. See if the washer goes through with the cycle as normal. If the washer performs correctly, then it has been reset and is fixed. If not refer to more troubleshooting techniques and causes of problems below.
Beko wma641w reset
hi
to reset these al you do is press and hold the start button for about 5 seconds then it should reset if not then you have a faulty pcb
regards
Mar 22, 2009 | Washing Machines
Reset
If this Err message is displayed constantly and the machine refuses to heed your attempts to select any programmes I'm afraid this means contacting the Service Force company who deal in Zanussi appliance spares, user manuals and machine dealings
Here is the contact phone number should you need it.
08705 929 929 www.serviceforce.co.uk
Hope this solves your headaches
Dec 12, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
My lg washing machine shows LE alarm code
Hello Claudecyr,
Welcome,
You said, your lg washing machine shows LE alarm code
Try this!
Unplug your washer for 10 minutes. If you can't reach the plug, turn the breaker off.
then when you turn it on the system should have reset!
And you will more than likely be fine!
Please let me know!
Huuum.
I think you will be solved.
Please remember to leave a rating! A solved I hope!
Oct 16, 2008 | Washing Machines
Smeg WDI12 Front Load Washer / Dryer Logo
120 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
