Question about Canon i850 InkJet Photo Printer
Ip5000 printer no magenta showing on test printout, after installing new magenta catridge, tried cleaning all the nozzles a number of time also.all other colours showing ok?
  • 76 Answers
This could be down to None canon carts clogging the head up or clogging the purge unit up, If they are all canon carts it could still be down to the print head, if not it could be down to the Logic Board. At the worse case it could be down to both printhead and Logic Board
Hope this helps
Posted on Oct 20, 2008
I use new remanufactured epson replacement cartridges for my epson stylus nx400. have been doing it wth no problems for a year. left printer idle for 2 mths. tried to print in color and the colors come out...
2Mths is a long time to leave an inkjet unused and it may take several head cleans to clear and blockage (caused by dried ink) A test page will show if and when the heads are clear.
Oct 18, 2009 | Epson Stylus NX400 InkJet Printer
Magenta not working when printing colors
try to wipe it in a wet cloth to remove the clogs on the nozzle that avoid it from jetting...load again your catridge on the carrier or cartridge holder....
and run maintenance page on it ...go to your printer panel and select maintenance and then select clean printhead..to print a maintenance page..or maybe your magenta has have a low ink condition..
thank you for using fixya..
good luck..
May 19, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon ip4200 one cartridge/nozzle does not work
Put isoproply alcohol on the nozzel with a connon swab until it melts(desolves) the drived ink.
Feb 07, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Aug 14, 2008 | Office Equipment & Supplies
Color problem
Chances are your othe cartridges were low...
When you install a new cartridge your printer does a head cleaning, and it uses alot of ink...
If the others were low, your printouts will show magenta as its the only color left...
Feb 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Won't Print Any Ink
well? how old is your printer?. does your printer head is new?
reason why doesnt have printout:
1. the unit doesnt recognize the printer head:
solution: turn off the unit and turn it on again.
2. Defective logic board.
solution: replace logic board.
3. Defective printer head
solution: replace printer head
4. Clog printer head
solution: wash the printer head with water..make sure to dry
before you install it to the printer.
5. Defective purge unit.
solution: replace purge unit.maybe it wont suck ink because of the loose or broken springs under caping of the purge unit..
6. inktank.
solution: check the lips of inktank maybe it much shallow so it
wont touch the nozzle of printer head..
you need to cut the edge of the lips of inktank so it will touch
the nozzle of the printer head.
Dec 08, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Only one colour showing at time of print
Maybe the ink well nozzle area has some dried ink left from the old cartridge. Remove the new cartridge carefully, and using a wet Q-tip,clean the area. Replace back the new black cartridge.
This worked for me ....good luck !
Sep 29, 2006 | Epson Stylus C64 InkJet Printer
Canon i850 InkJet Photo Printer Logo
49 people viewed this question
old marine
old marine
