Question about Bugaboo Cameleon - Tailored Fabric Standard Stroller
Bugaboo Parts - where can I buy a replacement handle bar / carry handle?
Where can I buy a carry handle / bumper bar (not sure what it is called, the bit that goes in front of baby on the pram) ? I am also after a shopping basket to go underneath for my 2008 model Chameleon pram
  • Anonymous Mar 16, 2014
    Bugaboo chameleon bumper bar
    Scholar:
  • 135 Answers
You should purchase your accessories direct from www.Bugaboo.com
email: serviceus@bugaboo.com or call 1-800-460-2922. This way you can make sure that you don't void your warranty.
Good Luck! from Moms Just Know
Posted on Oct 26, 2008
Hi my handle bar is not locking into place and easily swaps between off road mode and normal, is this kind of thing fixable??
This is not safe and you can call bugaboo, give them the number on your chasis and they will be able to help you. They will most likely replace since it is a big problem as it is the carry handle.
Feb 04, 2013 | Bugaboo Cameleon Baby Gear
When bumping up stairs handle bar extends, and feels loose (handle bar is very wobbley)
The Bugaboo is not the ideal stroller for bumping up and down stairs, The reason being it's core design. Most stroller handles have two or more mounting points to the frame but most strollers have baby facing forward and facing the big bad world and not Mummy. The Bugaboo is very clever, the handle can be locked ether way and the seat face either way but the handle has only one point where it attaches to the frame and that point has to rotate and lock. To give you an idea of the forces involved a crow bar the length of the Bugaboo handle can pull six inch nails out of hard wood!
Unfortunately Bugaboo have not used the best material solutions in this critical handle lock. They use a plastic disk to move aluminum locking pins and they fail if you bump down to many stairs. This happened to our Bugaboo in New Zealand. I repaired ours and now I help others by making or sourcing the better quality parts to repair them. I use aluminum for the disk and stainless steel for the pins.
If you are lucky another to have a Bugaboo less then two years old and still have proof of purchase documents Bugaboo will replace the frame for you. If it's older you can buy a new frame for around $400 but this will also increase you resale value by around $200 when you sell it. Lastly you can repair it for around $100 a side depending on parts required, Click on my name and you'll find many posts on how to repair both the Handle lock and the Handle extension lever or wing-nut. macnutz_23.jpg
Nov 26, 2010 | Bugaboo Cameleon Jogger
My Bugaboo Frog has a split in the foam on the handlebar. Can this foam be replaced, if so where can I get it in the UK. Thanks, Jane.
The foam is a product called neoprene tubing and can be found at specialist rubber product suppliers. Google a local supplier. Changing the grab bar rubber is easy just use hot soapy water but the handle bar is a problem as the foam is fitted before assembly and it would require disassembly to replace. This is not easy as the handle is riveted on and has internal parts to operate the handle locks. You can buy a special glue for repairing wetsuits to fix the split and stop it opening up further.
Nov 13, 2010 | Bugaboo Cameleon Jogger
How to change foam on handles
See if you can unscrew the handle bar first.
Then search for replacement foam online, maybe on ebay or bugaboo website.
And when you have bought the replacement foam grips, you can take a look here to see how to attach them yourself.
http://www.ehow.com/how_6730072_change-bike-grips.
html Bike grips and stroller handles work the same way.
I just used this post on e-how to replace my maclaren triumph foam handles.
Works like a charm - and it's sooo easy!! :)
Sep 26, 2010 | Bugaboo Cameleon - Tailored Fabric...
I've lost the carry handle/safety bar for my cameleon where can i get anotherone one?
If you contact www.bugaboo.com you will be able to get a replacement.
Hope this helps.
Sep 11, 2010 | Bugaboo Cameleon Jogger
Form on handle bar has ripped can i repair it
I'm not sure if you can repair it, but you can cover it. Check out handle bar, bumper bar and bassinet/ seat frame covers for your bugaboo stroller foam at www.bbsprouts.com
Apr 27, 2010 | Baby Gear
Replacement foam for quinny buzz handlebar
Hello I am making handle bar, bumper bar and frame covers for the bugaboo and can probably help you with a cover.  Contact me at www.bbsprouts.com
Diane
Mar 08, 2010 | Quinny Buzz 3 Sulphur Jogger
Use of Bugaboo bumper bar for Bugaboo Gecko
In short, no! There is no way for a bumper bar to be attached to a Gecko model.
Hope this clarifies for you.
Feb 22, 2010 | Bugaboo Gecko Stroller
How do you fit the bugaboo parasol to the carry cot on a bugaboo cameleon?
I always clip mine onto the carry handle bar that goes across the carrycot, that seems to work quite well, as it is directly above the baby. Although i hardly use it at all, as the carrycot has a hood and apron that give almost complete coverage to baby.
Jul 30, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon - Tailored Fabric Standard Stroller Logo
2,562 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
