Question about Ricoh Aficio 1035 Copier
Add toner I use a Ricoh Aficio 1035P. The display screen shows "add toner".evan after i add the toner inside the bottle the screen shows " add toner"..replace toner bottle..
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there toner in the bottle right now?
Toner bottle holder may be clogged, doesn't hurt to clean it anyway. Lift green handle and pull out bottle. remove bottle ,then remove unit from copier. You must remove the stopper on the left end if unit to remove. Take out doors if possible and work handle up and down and shake out toner, then vaccum.replace in copier and put in bottle. With the bottle holder still out, push bottle forward toward you and push donw handle. keeping the bottle in the forward position, turn the bottle clockways with your right hand. Turn five or six turns. Now push in part ways, lift handle then push to home position. Once in, tap the toner unit where handle hooks on a few times . This makes sure all the toner drops. You may wish to do this two
or three times. Close front door and let it run for a while, may work. If not,
try a developer initialization 2-801 and do the toner thing again. I realize you can do a toner add mode instead of the above but this is faster. Good Luck
Posted on Apr 20, 2013
Replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Posted on Oct 26, 2008
Ricoh aficio mp3010 ,i will change n?ew toner then againe coming add toner mesege,why
Have you replaced the developer yet???? It could also be the unit that the toner bottle goes into. There is a paddle wheel inside of it that move the toner and it may have broken up... Good Luck
Jan 15, 2013 | Ricoh AFICIO MP 3010 COPIER. REFURBISHED....
My machine aficio 2045e give error toner signal even though toner in bottle is more than50% i make every thing but still appear add toner
Inside the toner feed mechanism there is little plastic fins that tend to break off. You will probably have to replace the hopper unit (The unit that the toner tube sits in) or in that unit where the tube opening sites you can either replace the feed chuck or if your handy maybe repair the feed fins. The chuck part pops out with plastic tabs.
Sep 14, 2011 | RICOH RICOH AFICIO SP C820DNT2 40 PPM...
We have a Ricoh Aficio 350 copier that is quite old but has worked well through the years until now. It keeps displaying ADD TONER and runnng after we have already put in a new cartridge. Under add toner,...
take the toner supply unit out. toner supply unit is one where toner bottle fits and vacummed clean the unit. the toner unit is blocked. i am a Ricoh technician.
Sep 23, 2010 | Office Equipment & Supplies
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
My Ricoh Aficio MP 161 said to add toner but still won't copy
Check your old toner bottle and make sure the plastic "cap" is still in the bottle. These machines have an occaisional problem with the caps coming off (not the black screw off cap but the semi clear cap under the black screw off cap) and staying inside the black plastic "cup" that you insert the toner into. If the cap is missing it may be stuck inside this cup. If the cap is still in your old cartridge then try opening/closing the front door and letting the machine cycle to see if the toner light goes out. May have to do this several times. Had one customer just yesrday have to do this to clear the toner light after adding toner.
Good Luck.
Jan 28, 2010 | Office Equipment & Supplies
Ricoh aficio 2035 keeps telling me to add toner
Sounds to me like the 'plunger' from the top of the bottle may have remained in the machine when you removed the other bottle, and is blocking the flow. Remove the toner bottle and check.
Otherwise, are there any other messages showing, such as "close cover", or something similar? If so, these machines did have a problem, that I may be able to advise you further
Jul 10, 2009 | Ricoh Aficio 450 Copier
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner is stored in the Transfer Belt assembly on the right door that you open to remove a jam. Remove one spring on each side and release the catch while gently lifting up on the belt and roller assembly. It swings 90 degrees up from the rest of the assembly. There are 6 screws that hold a cover on the lower assembly. remove it and dump the waste toner. *** VERY MESSY*** have a vac on hand. Not a shop vac unless you want toner clouds floating around the office. If the six screws aren't present, dump the toner out of the **** between the mylar-rubber blade and the lower assembly. once this is done, the message will clear.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
689 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
