I am running Vista via cable extreme, boy have there been some issues for about 14 months, get to the problem at hand , on start up (boot) before the net connects, this appears, Load Sercomm Library Error or Version is too old. can't get rid of it, tired of uninstalling, is there a quick fix ?
Yes, i am using the latest download from Netgear wg111v2-3-4-0.
Double click smartwizard, same thing, once i click "ok", all works fine, till i reboot.
Thanks in advance.
SOURCE: after install of driver into windows, xp doesnt
Hi, please check the status of the adapter using the steps below:
1. Click Start and go to 'control panel'.
2. Double click on 'system'.
3. Click on 'hardware'.
4. Click 'Device manager' button.
5. Under 'Network Adapters' you will find the name of Netgear adapter.
Check if it shows installed properly or shows with an error code.
You may try installing the adapter on another machine to isolate the issue further.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
SOURCE: serComm library error and version is too old
Hi, perform the steps below to configure wireless connection settings on the concerned computer:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Regards
Anand
SOURCE: netgear wg111v2 drivers mac osx 10.3
Hi, Download them from here:
http://kb.netgear.com/app/answers/detail/a_id/714
Regards
Anand
SOURCE: load sercomm library error or version too old !!
HI, Update the drivers for the adapter. Visit the link below to download the latest drivers for the adapter:
kb.netgear.com
Goto downloads and select your product model.
Regards
Anand
SOURCE: Everytime i start my computer it tells me that
Hello
Al you need to do is download an updated driver for the device you are using. Remember to download the driver for the specific operating system that you are using. Now just install the new driver you have downloaded. Hope this can help you.
Best regards
Andrea
When I boot up my system I get Load SerComm Library error or version is too old. Tried to uninstall, then reinstall but does not help. This is the second problem with this stupid netgear adapter since I got in about 3 months ago.
Yes, I am having the same problem and i get the error message every time at boot up. I have looked all over the net and not getting a fix. Any ideas?
Same problem here but only started after I did a re-installed windows XP. Error doesn't seem to affect anything but always annoying having errors come up. Any one have any ideas?
i have the same problem and connot figure out how to get rid of it- do you think the cable tech's might have an idea?
I have the same problem, just started today, and yes it was after I reinstalled Windows XP, actually I took my Dell comp back to factory default, wiped it clean. Has anyone figured out how to fix this?
I have the same problem. Had to download an update for my netgeear WG111V2 device so that it would work with my new computer and Vista Home Premium OS. Get the same message everytime at start up. Thanks in advance to whoever has a fix for this.
Nobody has a fix?
I have exactly the same problem, except I am running XP.
Same them. Error messages saying Load Sercomm Library error or version too old, each and every time I start up on Vista. Download Detective which scanned my computer and said a driver was missing. Look to se if I could find one for my Netgear WG111v2 but nothing. My wireless works fine but it's still annoying.
have same problem but it is also causing blue screen of death at seemingly random times.
hmmm..well..sounds to me like the authentication drivers are getting corrupted at each recycle step. maybe that is something that is inherent in this design?
