Question about Gateway EV 700 17" CRT Monitor
Wavy Vertical Line
Out of the blue a wavy black line has appeared to the left side of my monitor screen. It appears at the top and bottom but does not connect. It looks like a worm. I thought maybe it was some kind of worm and did my normal scanning and it is still here. Nothing was found in my AVG virus scan. I have restarted my computer several times but the line is still here. HELP!
  • ZAPP59 Feb 19, 2008
    Much more a black swirl over a number of televisions that I am responsible for in work
Bad capacitors.
Posted on Jul 23, 2008
Error : Out of range
Posted on May 12, 2008
Change refresh rate of monitor.
Posted on May 09, 2008
  • 26 Answers
You have AC ripple getting into your horizontal output. you have a power supply problem in the monitor. take it to get it fixed.
Posted on Jun 28, 2006
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
There is a thin blue vertical line, top to bottom that appears on the right hand side of the monitor,
it is a dead line much like a dead pixel the screen will need to be replaced
May 08, 2010 | Computers & Internet
Wavy line on bottom and top of widescreen line?
Its filter in vertical section is leaky.
Dec 30, 2009 | Sanyo DP42849 42 in. HDTV
Picture is wavy and has black vertical and horizontal band
The following are supposed to be checked on the horizontal and vertical,
the supply of the sawtooth oscillator
eletrolitic capacitors near a line transformer
zener diodes
and driver transistor a round that area.
Apr 08, 2009 | Toshiba 35A44 35" TV
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Wavy Lines
some type of electrical feedback try upgrading your cables or tightening the ones you have. what might work best is a line conditioner i filters out any feedback you may be getting and cleans your power supply they cost from 50.00 and up best buy or circiut city both carry them or online as well
Jul 17, 2008 | Sony KP-53HS10 TV
A black vertical line on my screen
it risky if you always use your monitor that has a factory defect..i suggest to return to the store for some replacement of your monitor...coz your monitor has a warranty.
Jan 28, 2008 | ViewSonic G810 21" CRT Monitor
Gateway EV 700 17" CRT Monitor Logo
840 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
