Question about Honeywell Heating & Cooling
I cant get my thermostat to work i am freezing!!
    New Friend:
  • 30 Answers
Check your breakers
Posted on Oct 30, 2008
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
Fridge is freezing everything and staying on 3 degrees
Hi, the thermostat is faulty replace it. There is nothing else that can make a fridge exceed the set temperature but the thermostat.
Sep 10, 2014 | Refrigerators
Frost free refrigerator not working..heater has resistance, cant determine if defrost timer is working correctly
One way to check the timer is to put a pen mark on the timer dial, say at 12 O?lock position. Have the fridge running for a few hours and check back and see if the marker has moved.
Another item in the defrost cycle is the DTT. (Defrost Termination Thermostat). This thermostat works in reverse and has continuity below freezing temperature. Therefore to test this you need to check coninutity by placing it in a bowl of ice for a few minutes.
Good luck
Ash
Sep 13, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freeze control on my PF1222TB is not working. Whenb the temp drops below the temp set on the contol, it does not start the pump
Freeze control is a thermostatically controlled switch.
There are 4 basic components:
-Wire connections that can come loose. Check that wire terminals are tight.
-Thermostat setting that can be set lower. Move dial and see if that has effect.
-Thermostat that can go bad.
-Internal switch that can stop working.
Replacement freeze control can be purchased separately:
Google search: Intermatic freeze control replacement
http://www.inyopools.com/Products/02400004003524.htm?CS_010=3524&CS_001=1013946&CS_002=1016676
Jan 11, 2011 | Intermatic Timer PF1222TB Multi Circuit...
Fridge too cold
its a faulty thermostat,,its stuck in the on poshion,,, thats how they fale most of the time so as to save the food inside them,,,,they then freez solid!
Jul 10, 2010 | Sub-Zero 680 / F
Cant adjust fridge temperature
sounds like a bad thermostat
Feb 24, 2010 | Refrigerators
Hit up engen and doz not work heting
you got a air lock in the systen losen the bleeder valve on the thermostat housing and let the water circulate and keep filling it up with water till it stops losing air
Jan 13, 2010 | 1998 Volkswagen Golf
Freezer over freezes,whats the correct setting?
The thermostat maybe defective. It will not over freeze even at the lowest setting.
May 27, 2009 | Refrigerators
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Kenmore Side by Side Refrigerator
could be, but can also be a MAJOR problem not worth fixin! thermostats usually tend to be relieable for that they either cool althe time or quit altogether, the fact that freezer cant freeze ice, sounds as if its running(thermo good) perhaps a freon leak , not enough freon, bad compressor or some other sealed system issue
Nov 10, 2008 | Kenmore Refrigerators
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
