Question about Video Game Consoles & Games
My PS3 when switched on goes to the wavey lines (just before the menu screen) and then freezes? it also stops making a sound. i've switched off at the mains but the problem persists. any thoughts?
  • vowlesy Oct 20, 2008
    Unfortunately this did give me early hope in that it asked about the settings but it still froze at the wavey lines just before the menu kicked in. Have you any other thoughts? Your help is appreciated.
    Sergeant:
  • 196 Answers
It looks like your system may be corrupt try hard resetting your system turn off the power in the back of the ps3. Turn it on while holding down the I/O utton until it beeps 3 times
Posted on Oct 20, 2008
When i go online with my ps3 playing black ops it freezes then dosnt work it starts when the background music stops then resetting a blue screen comes up then goes back to user menu
If your PS3 is freezing up then you need to stop the heat build up internally and to do this you will need to get it repaired.
Now you can send it in and they will fix it for you that is the standard method however bear in mind that there will be a repair charge of $150 for the fix which is quite steep!
The other way that you can fix it is by using a good PS3 Repair guide.
Just a quick word of advice though, make sure you check out these reviews of the top guides so you can be sure what they offer.
Click Here To See PS3 Repair Guide Reviews
Hope this helps.
Mar 25, 2011 | Sony Playstation 3 (PS3) Console
Will not start up. when you power up it looks ok but it sticks on the "wavey line" screen. the wavey line is continually moving but thats all that happens
Most likely your hard drive has failed. This is one of many signs. Replace your hard drive with one similar or even with a larger capacity. I recommend 120GB 5400RPM Seagate or Western Digital. Thanks and good luck!
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
Home screen shows only backround. No icons
Switch the PS3 off (Red Light). Hold your finger on the power button until the PS3 switches on and off. Take your finger off and hold it in again. It will come on. Hold it until you hear a double beep and take it off immediately. You will then be taken into a recovery menu. It will ask you to connect your controller via USB. Choose option 3 - Restore File System (Do not try any other option as it will erase some or all data on your HDD). It should work after this.
Hope it helps you.
Nov 05, 2009 | Sony Playstation 3 (PS3) Console
I have wavey lines going accross
the screen?Check what settings your tv is on switch the viewing styleabout ect..780p-1080p to see what your tv preffers
Aug 15, 2009 | Sony PS3 40GB Best Sellers Bundle Console
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
I put in a BluRay movie and it shows on the menu but when I hit X to play it, the screen goes black and will not play. PS3 games are hit and miss.
It sounds like you are having a firmware problem. This is common with blue ray. You will have to go to the ps3 site and download the firmware upgrade for your system. I think you can upgrade automatiacally if your ps3 is hooked up to the internet. Go to menu settings and look for updates for firmware or divers...
Please don't forget to give very good ratings, they are important
Aug 07, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont boot past the title screen!!
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
This will fix it for sure.
Jan 23, 2009 | Sony Playstation 3 (PS3) Console
Wont start up
we have the same problem but i got one step to make it enter the system,, when turning on ur ps3 u nid to hold the switch until u hear the 2nd sound,, once that happen the system will show up but there is still a problem in my ps3,, u can see the system but it will not load games or any video icons in the system,, u will only see settings configuration there but once u click it the ps3 will freeze,, comment me if u had the same problem in entering the system,, i doubt that i need to format the hdd via pc,,
Oct 18, 2008 | Sony Playstation 3 (PS3) Console
PS3 Freezes at the starting screen
well i got my thanks for the links, this is for the psp and not for the ps3, but its worth a look around if you like all games related stuff, well here is a update for you guys.
After i had the freezing problem at the startup screen (the same as you guys, so this means its a common fault because its at the same spot at the wavey line!!!) i sent my console to some local guy here in england for repair, it cost me £90 in total and was done in 5 days all fixed and working and back to normal, but the thing is its a common problem......hmmm all you guys have had the same thing happen!! at the same startup screen!! its sounds like some kind of software fault as it was fine before all the updates i have to keep doing to play my games, since i had to do software updates it all went wrong, but not all people have had this problem at the startup, my friend has had a ps3 as long as me and also done all the updates and he has had no probs at all, well if it seems that a company can fix your ps3 then someone somewhere knows about the fault and is not saying a word to all us unfortunate ps3 owners, if your in the uk and want the repair address drop me a line.
THE STORY CONTINUES......................................
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Wavey coloured horizontal lines and no sound
sounds like a bad eeprom.If thats not it start looking in the power supply.
Apr 11, 2006 | Toshiba 51H83 51" Rear Projection...
Video Game Consoles & Games Logo
104 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
