Question about Panasonic Microwave Ovens
Cannot start model nn-mx26 - Panasonic Microwave Ovens
  • Panasonic Master
  • 13,433 Answers
It doesn't work at all.. READ HERE
http://www.repairclinic.com/0088_6_1.asp#Level1_1
More.. here
Good luck.
Posted on Oct 20, 2008
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
NN-MX26WF
Go to panasonc site and request on line
Oct 03, 2009 | Panasonic NN-MX26 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
PANASONIC MICROWAVE-NN-S615BFX
These H codes usually indicate a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Sep 25, 2008 | Panasonic NN-MX26 Microwave Oven
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Interior light does not go on
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Panasonic NN-MX26 Microwave Oven
Tray
The most likely causes are a bad turntable motor, a bad turntable coupler, or a problem with the wiring to the motor or on the controller. Also, you might check your manual to see if there is a feature to turn it off. It may be set to off. You can find the owner's manual online here: http://panasonic.com.au/content/library/files/F001226.pdf or http://manualshark.org/manualshark/files/24/pdf_17508.pdf You can get any needed parts here (enter your model number without any dashes) http://www.pasc.panasonic.com/epartr If you need more help, please reply back. I appreciate your thoughtful rating of my answer.
Oct 05, 2007 | Panasonic NN-MX26 Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
