When i try to print something the paper wrinkles up and does not print
Depending on where exactly the page stops in the printer. If in the paper tray area you may need new paper pick up tires. If it stops just after the toner cartridge you could have a bad fuser or bad fuser drive gear which is on the swing plate assembly. Or it could as simple as the toner cartridge.
Posted on May 26, 2010
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
May 14, 2014 | Kyocera Office Equipment & Supplies
When we print something,the paper comes out and is wrinkled and has some ink on it in places where there is no print. The fuser checks out fine.
Description sounds like the fuser rollers are bad.
To check it out run a 1/2 test.
Put paper in the manual feed tray. Print something. As the paper gets 1/2 way into the printer, open the top cover,(you might have to print a few sheets to catch it just right) take out the toner and look down at the paper. If it is wrinkled, you could have a bad toner cartridge. If it looks good...get the fuser replaced.
Jun 15, 2011 | HP LaserJet P3005n Printer
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
Wrinkling Laser Paper
Sounds like something is either wrong with the rollers, something is stuck in there or you are using the wrong type of paper.
I suggest you take a peek inside there and see if there is anything noticeably wrong inside. If not then look up what type of paper it needs.
Jul 10, 2009 | Xante Accel-a-Writer 3N Laser Printer
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
162 people viewed this question
k24674
jasbo
jasbo
