Question about Acer Computers & Internet
I was muting the sound from the mic on my notebook and now I cannot get any sound from the speakers. Could you please help.
    Genius:
  • 1,226 Answers
did you see the volume control in the task bar? you can double click that and then set the not to mute or uncheck the mute option. of the volume, mic and other setting.
you can acces this also the control panel in the sounds and audio controller. "Double click the sounds and audio devices then set the or uncheck the mute option.
may this help you.
melnavz
Posted on Oct 20, 2008
My sound won't work. The speakers are ON, not muted, and all wires are connected.
check that the speakers are not connected into the mic socket.
go into control panel and select sound and settings.
go into loudspeakers and check that sound is turned up.
I hope this was helpful.
Jan 11, 2011 | Acer Aspire One PC Notebook
The mike of my headphones is not working.Even the inbuilt sound recorder of windows XP can't record any sound from the mike..The mike is working fine in other Laptops.I have installed all the...
make sure that your mic input is not muted. look under control panel/sound and audio devices, then under your microphone, select "volume" and make sure the input is selected (with a chack mark in the box under the mic volume control) and not muted.
Oct 12, 2010 | Compaq Presario 700 470024-192 Notebook
My computer speakers stopped working after installing Logitech quickcam deluxe for notebooks. Please help.
Run an audio check
XP
Plug in your webcam or headset or mic you wish to use with your webcam
Control Panel (Classic View)
Open 'Sounds and Audio Devices' folder and click on the 'Volume' tab - make sure the speakers are not muted, open 'Speaker volume' and set the sliders toward the upper end.
Open 'Audio' tab - make your preferred mic the default device in the 'Sound recording window'
Open 'Volume' below the window to ensure the mic is not muted
Click 'Apply' and 'OK'
Restart your computer
Configure the webcam / mic to your chat program
VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
Right click on the volume graph and select 'Show disabled devices' and 'Show disconnected devices'
To set your preferred mic as default - click the mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Aug 28, 2010 | Logitech QuickCam Deluxe for Notebooks
Mic
Try a different set of headphone, if it works, then it is the headphone set.
If you get same problem with all headphones, then
If you get no sound: ensure that you have sound from speaker, if you get sound from speakers and no headphone working, then there is a problem in the headphone connection.
If you have no sound at all , not even with speakers, then check audio settings in control panel, ensure audio is not muted. If audio settings are OK, then you need to reinstall audio driver, or you have a faulty audio card.
Additionally, if it is only the mic not working then do the following:
Go to control panel and open sound and audio device.
Open volume settings and find settings for mic.
Tick off the mute option.
The mic is muted by default in Windows, that is usually the reason why it is not working.
Sep 14, 2008 | Compaq Presario 700 470024-192 Notebook
MIC PLAYBACK IS NOT COMING OUT TO THE SPEAKERS
Dear sir/madam,
Go to the sound properties in tray icon, check the Mic is not muted and there is Line in button, u scroll up to high for sound in mic. check all the check box are not MUTED. ok.
thanks
good luck
Don't forget to rate the solution
Jul 23, 2008 | Microsoft Windows Vista Home Premium with...
Compaq laptop c700's mic is not working (sound setting is ok)
My laptop model is compaq presario c754tu, I have installed Windows Vista Business, and the audio is working fine, but the internal mic and external microphone both work together........i want to mute the internal mic..... how i can do it ? please reply me on my email id i.e. vsdoshi@gmail.com
Jun 28, 2008 | Compaq Presario 700 470024-192 Notebook
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
Jun 10, 2008 | Logitech Labtech Verse 524 Microphone
Audio feedback
put your mic on mute for playback. So the mic works but it doesnt play it from the speakers at the same time.
If you dont see microphone on the list click on
options then settings
put a X on the playback -> microphone.
close settings
its now shown in the panel, click on mute and it wont feedback the sounds to you anymore.
May 09, 2008 | Acer Aspire 3000 Notebook
Skreeching sound comes from speakers when ever I switch it on, I cannot bear it so I connect a microphone plug. Looks like the mic is on, how can I switch it off. Paul
click on the speaker icon at the right bottom , go to the properties and then at mic option and click on the mic box it will get muted
Apr 28, 2008 | Toshiba Qosimo G35-AV660 Notebook
Sound problem
Is your problem happening only when you use skype messenger? Check if your mic is on mute by double clicking the speaker icon on the taskbar beside the date&time. Check also if there is a driver installed for the audio mic and sound to work by right clicking on My Computer then go to Properties, on the System Properties window click on Hardware tab then click Device Manager. Look if the speaker icon -- the Sound, video and game controllers-- has a Critical icon(a yellow triangle with an exclamation point inside). If there is a Critical Icon then there is a missing driver for your sound. Fix this by installing the driver or just check first if your mic is on mute. Otherwise your mic is busted.
Apr 13, 2008 | Averatec 3200 Notebook
Computers & Internet Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
