Question about Olympus FE-230 Digital Camera
The auto focus is not working I have blurred pictures
For unknown reason my camera just quit focusing and I use it for work. I didnt drop it, it's useful equipment i possess. Will can it be fixed if I send it in. Thank you.
Model: FE-140 I had it for only 9 months.
Posted on Dec 15, 2008
  • 23 Answers
Hi... do you get blurred pictures at all focus... check that and confirm if the prob is with the focus or lens...
Posted on Oct 20, 2008
My auto focus isn't working, it seems to be sticking, my pictures are blurred.
Sounds like you are in manual focus. Look on lens for M-MA button. Be sure you're on MA. Also look on camera for M / A and be sure you're on A.
Aug 10, 2014 | Nikon COOLPIX Cameras
My 100-400 mm EF canon takes too long to auto focus.I like to take pictures of flying birds and i get alot of blurred pictures even at a shutter speed of 1/3200sec. I use the #2 position on the stabilzer...
Manually pre-focus to the distance you'd expect then the auto focus won't have far to move/lock on. Only turn the IS off if you are using a tripod. The auto focus works by detecting a difference in contrast so if the conditions are not compatible i.e a BG the same as the subject it will 'hunt and peck'.
Jan 26, 2014 | Canon EF 100-400mm f/4.5-5.6 IS USM Lens
The camera is set on Auto. The pictures are a blur, not in focus. Is there a way to set up good focus?
Revie manual here:
User Guide.pdf
This your camera:
Nikon Coolpix 775
1.check your lens camera is clean and clear.
You have to choices, auto and scene.
What happen when you choose scene mode?
2. test change your image quality to normal. you can go to menu even in shooting mode.
3.change image to normal and back to shooting mode and try again
It is same ?blur?
4.if still blur, try go to menu mode again, at left side you can find BSS.
5 IF BSS is off.. change it on. if it is on, change it off.
6.go to shooting mode again.
that all. good luck and rate me..tq
May 12, 2011 | Nikon Coolpix 775 Digital Camera
All pictures are blurred and when looking at screen its blurred
Your camera's Focus mode may be set on Macro Selectable in which case the Auto Focus Range will be "wide: 0.07–0.7 m, tele: 0.4–0.7 m (macro AF)" as quoted in the specifications from www.kodak.com web page for the EasyShare M1033. While this setting is great for a close-up of a flower, anything more than a meter (about one yard) away will be blurred unless you reset your Auto Focus mode back to "normal AF" or "landscape mode"
Jan 07, 2009 | Kodak EasyShare M1033 - black Digital...
Blurred images
i beleave on auto, the a75 has auto focus, there is a 1/2 second focus time before the picture is taken, enough to blurr the picture
Jan 03, 2009 | Canon PowerShot A75 Digital Camera
Picture blurred
There can be several reasons for blurred pictures.
Are you taking the picture in enough light? Is auto focus turned on? If not, are you focusing correctly? What sort of camera are you shooting with?
Apr 07, 2008 | Cameras
Cybershot H7 focus problem
Things to check before you assume it is a mechanical issue-you can get vibration message if flash is disabled, be sure also that the macro mode is not enabled-this is very common on sony cameras to turn on by accident-flower button on camera will put in close up mode and you will get blur make sure no flower is present on lcd screen-if in macro press button on camera w/flower to turn off-also in menu you have continuous and monitor auto focus settings try changing one or the other and see what happens
Mar 18, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
I need advice on how to take Ice-hockey action pics...
Pictures get blurred because of several reasons:
Low shutter speed - occurs in low lightning conditions.
Auto focus not focused - occurs when pressing the shutter button all the way without waiting for the auto focus ready signal (green box)
To speed up the shutter do the following:
In Camera menu-Quality- Set ISO 100 for outdoor, ISO 400 indoor.
To avert focus problems, set camera menu-Rec- Focus-Infinity, Rec-Quick shutter-On
Hope that helps.
Dec 28, 2007 | Casio Exilim EX-S500 Digital Camera
BLURRED PICTURE WHEN USING MOUNTED FLASH.
If you are not using canon lenses then the low light focusing aid will not work correctly. Go into the menu and turn of the flash infra red light
Jun 10, 2007 | Canon SPEEDLITE 580EX TTL Flash
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Olympus FE-230 Digital Camera Logo
387 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
