FixYa.com
Tags:
Bosch 24 in. SHX36L05UC Stainless Steel Built-in Dishwasher
Dishwasher doesn't fill/How to check... (by 2 users)
posted by Tahoedog on Jun 26, 2006
Set the washer to run its normal cycle and went out for dinner. Came home hours later and washer is still running. Can't get reset/self test diagnostics through manual or other source. Found a clog in the breather valve and have cleared it. When attempting to snake the drain line, the plastic hose detatched and the soapy water that had remained leaked out under the machine. Now, machine sounds like it's running constantly, trying to drain. I've filled the bottom with water and when I press the on/off switch, the water is drained away, but the machine doesn't go to the next cycle. Is there a "reset" button or switch for this model?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Walt88, posted on Nov 22, 2007
Different model SHX46A05UC, same type of problem. Can't find manual so used diagnostic test instrux from other models given on this website. Delicate/econo button flashing.
Can you Help with these Dishwashers problems?
Dishwashers
after washing dishes, there are
after washing dishes, there are... Answer This...
Dishwashers
no water intake into dishwasher
no water intake into dishwasher... Answer This...
Bosch 24 in. SHX36L05UC Stainless Steel...
Bosch dishwasher problem
Hi, Mira~ I noticed that you... Answer This...
Bosch Stainless Steel...
model E-nr sm17052us/08... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
