Question about HP LaserJet 3050 All-In-One Printer
Printer is not able to pick up the page for printing and displaying NO PAPER PICKUP PRESS [ ENTER ] when there are paper have been loaded already. and we have also checked and we have not found any kind of jam too.
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Replace or repair pick up rollers....
Posted on Oct 20, 2008
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
Bad print quality
Follow the steps listed below to print the PQ troubleshooting pages. These pages consist of one procedure page and five color test pages.
  1. Print a copy of this Web page and walk over to the printer you are troubleshooting.
  2. Load either 8.5 x 11-inch paper (letter) or A4 in Tray 2 popup_i.gif of your printer.
  3. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  4. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  5. Press the Select select.gif button to select DIAGNOSTICS.
  6. Press the Down arrow down.gif button to highlight PQ TROUBLESHOOTING.
  7. Press the Select select.gif button to select PQ TROUBLESHOOTING.
  8. Pick up the PQ troubleshooting pages.
  9. Return to your computer to continue the troubleshooting procedure.
The message PRINTING... PQ TROUBLESHOOTING displays on the control panel until the printer finishes printing the PQ troubleshooting pages. The printer returns to the Ready state after printing the PQ troubleshooting pages.
Feb 17, 2011 | HP LaserJet 3600n Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Hp 4100 inkjet printer not recognizing paper in tray
Probably it's mechanical problem.This printers have more problems from this type.
Oct 01, 2009 | Office Equipment & Supplies
Printer says "printer mispik. [enter] to resume. so i press enter and it says the same thing.
Mis-pick means it didn't pick up a sheet of paper, you may need to clean the paper feed roller in the back above where you load paper for printing.
Jun 11, 2009 | HP LaserJet 3330 All-In-One Printer
Load paper
To resolve this issue pick one blank sheet and insert it in the tray and try to print self test page. If the printer prints self test page then load the paper properly and try to print. If self test page won't print then check the paper settings.
May 22, 2009 | HP Photosmart 3210 All-In-One InkJet...
HP 6180 Printing Problems
Are you getting the paper mismatch error message?
If yes, see below...
I will ignore the normal solutions to a "paper mismatch" error such as your settings not matching your printing media. Obviously, check these first:
If your problem is not solved with the above steps, you have an issue with your "spot sensor" and it needs to be calibrated. Instructions:
1. Press * and # at the same time, and then release both keys.
The display reads "Enter Special Key Combo".
2. Press 3, 2, and then 9, releasing each key before pressing the next.
The display window should read "Service: R0622M" with a revision number.
3. Press the right arrow button once.
The display should read "System Configuration".
4. Press Enter or OK.
5. You will be prompted to enter serial number. Do not enter any information
on the unit.
Press the right arrow button until "media sense calibration" appears in the
6. Load Paper into the unit and then press Enter or OK.
7. Media Sense Calibration process will take place.
Dec 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
** Paper Pickup
Check the paper pickup tray & roller may be its not working. If possible contact the local vendor for printer servicing.
Mar 09, 2008 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 3050 All-In-One Printer Logo
117 people viewed this question
Ben Johnson
