How do I connect A STB to VCR to TV - Televison & Video
  • 905 Answers
Connect the RCA jacks, audio ( red and white) and video(yellow) to the input on the vcr then hook another set of RCA jacks from the output of the vcr into the tv audio and video inputs
and thats it!
Posted on Oct 20, 2008
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
I need help connecting tv to DVD player VCR and satellite box
Connect as following
1. Set top box - RF cable from STB to antenna socket on TV.
2. DVD player output to Video1 on TV
3. VCR output to Video2 on TV.
May be you can route VCR through the DVD player or viceversa. That you can see and try on ground.
Sep 28, 2010 | Haier TN201AUV 20" TV
Set top box connection via VCR
Nov 21, 2009 | Samsung DVD-V5500 DVD Player/VCR
How to access the usb port on a samsung le32b450
according to the user manual,the USB port is intended only for software upgrade, here are some of the supported inputs for your TV : VCR / DVD / Cable STB / Satellite STB / PVR STB / AV Receiver / Game / Camcorder / PC / DVI PC / DVI / TV / IPTV /
Blu- ray / HD DVD / DMA
Aug 29, 2009 | Samsung Televison & Video
Using FIOS HD DRV STB with a VCR
Okay let me make sure I understand.. Looking at the back of your STB and VCR do you see an (IN) and (OUT) coxial connection?
If so, you can use the coxial connections to obtain your desired results.
I hope this solution is helpful. Please remember to rate thsi solution.
Feb 12, 2009 | Televison & Video
Tv has snow screen but plays movies fine, just no cable channels come in clear, some one has said maybe tuner. Sanyo DS24425
It may very well be the tuner. If it has another means of connecting to the tv try composite or component cable. If that isn't possible try replacing the coax from the wall plate to tuner and from tuner to tv. This is if you have a cable box also called an STB in your home. If you do not have an STB try changing the coax from wall plate to tv. You may even want to replace the barrel on the wallplate as well. If the cable runs through the VCR disconnect it and run it straight to the tv and this will determine if the problem is in the VCR.
Hope this helps you out.
Sep 09, 2008 | Televison & Video
PAL to NTSC conversion
You might need to input a code on your VCR Remote. Try looking it up on the Internet.
Jan 13, 2008 | Aiwa HV-MX100 VHS VCR
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
