Question about RCA TruFlat 27F520T 27" TV
Cable/antenna connector my male coax connector on the back of my tv broke off and i want to fix it i'm currently in iraq with my job and i can't get to a repair shop i need to get a part # or the actual name of it so i can get it fixed by the guy in the avionics shop can fix it for me thank you for your time mike
  • 905 Answers
You can try to get just the coax replacement , otherwise you will have to get the whole tuner, and the number for the tuner is right on the tuner , but just soldering in a new coax connector is cheaper
good luck and thanks!
cable/antenna connector - 71c7690.jpg
Posted on Oct 20, 2008
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
Hello, my 25" Magnovox (#mt2501c)
Tv fell off about 3 feets or more?Yes,turn on the tv see if u getting any power to the unit?Might have broken main PCB board too.If unit still have power,check see if tv get statics screen have colors shaded in red or mutiples colors,mean the tv CRT(tv tube) yoke is dead and damages scrambles radiation.Or the tv getting power but have high pitch sqeeling noises or rattles noises,tv have the CRT-(tv tube) is crack by the neck or broken totally.CRT have damages problems or dead tv is worthless,beacause of CRT(tv tube) is dead,not fixable even that antena connector input is replaced.
Feb 17, 2011 | Philips Magnavox MT2501C 25" TV
How to fix the antenna anolog cable connector that to coax cable connects to on back of TV.
Cut off the bad connector on the end of the coax cable. Go to Radio Shack, Home Depot, etc. and pick up a new twist-on coax connector, or a crimp on version if you have a crimping tool.
Twist the new coax connector on good and tight and you should be good to go.
Mar 30, 2010 | RCA HD52W59 HDTV Projection Television
How do you hook up regular coax cable to the TV?
You simply need an "F" connector to "Belling-Lee" converter. about $4.00. At any Radio Shack, Antenna shop. This screw onto the end of the existing antenna connection & makes it so you can plug it into the Socket at back of set.
I have included a link that has a picture.
http://cgi.ebay.com/1-Coax-TV-Adapter-Connector-PAL-Male-to-F-Female_W0QQitemZ110386773163QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item19b3907cab#ht_683wt_1139
Feb 16, 2010 | Sylvania 6842PE 42 in. HD-Ready Plasma...
Pulled plug (antenna connection) out from the back of the TV set it broke off tried to fix it and now lost the threaded male end can this be fixed & how much the dvd works great,ser#057340809675 upc#7...
You can buy the male coax threaded terminal at Radio Shack or Home Depot...some Walmarts carry it too. You can do it yourself, just follow the instructions on the package. You will have to strip the plastic shiething off the cable a little with a knife.
Feb 08, 2010 | Orion VR213 VHS VCR
Broken coax connection on back of unit
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Digital to analog converter box hookup
You will have to go to Radio Shack or Wall Mart, maybe Home Depot and get a matching transformer. That will have spade terminals on one end to connect to your tv and a round (75ohm male thread) to hook to your converter box.
Jan 08, 2009 | Televison & Video
Sharp 36R-S450 Coax broke off Help!!
it should be alot to fix all u have to do is buy the coax connector n solder it
Oct 28, 2007 | Sharp 36R-S450 36" TV
The cable coax male connection is disconnected from the television
The coax connector you describe is called the F connector and the silver box it is attached to is called the tuner. The original F connector or a replacement F connector can be soldered back into the tuner, but the metal frame of the tuner must be straightened out and the center pin must be delicately reattached too. This is quite an easy job but requires some labor, assuming that nothing was jammed into the tuner when the F connector was out and the coils behind the F connector have not been disturbed. I usually charge about $40 to reattach F connectors but if I have to replace the tuner I charge about $50 because it is a lot less labor to replace the tuner and they can be purchased for about $25.
Jul 17, 2007 | Sanyo DS25390 TV
RCA TruFlat  27F520T 27" TV Logo
198 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
