Question about GE (-25001RE2) Audio Conference
GE television My television is losing it"s audio and the picture is terrible. The volume has to be all the way to even get sound, and the picture can not be adjusted enough to get the color right.
My GE 32 inch won't come on, when you turn it on you can hear click two to three times then it comes off.
I have another 32 inch GE TV that has no picture except white/gray light on the picture tube, but there is sound
Posted on Dec 18, 2008
I bought a seiki 43" se34fgt tv and the volume is very tinny like it is in mono
Yeah, by hooking to your audio system. Most of these sets have
sh-- sound.
Dec 02, 2015 | Televison & Video
After the TV has been on for about 2 minutes, i lose the picture. i can still hear the sound, but no picture. I call HP and they want to charge me $630 service fee before they will even trouble shoot!
and the only troubleshooting they will do with you is this.
Press the volume button up and down to see if you can see not just hear but see it changing up and down. If you can see the volume changing then the television is not at fault. The problem would be the signal source (set top box or etc. from which you get your television channels).
If you don't see the volume changing then you know the television is at fault. Loose inverters or an inverter board that has failed is usually the cause for this. This is something that a local service provider of flat panel televisions can repair but you will have to pay for parts and labor. Be sure to get estimates so you can decide whether or not you want to buy another television.
Jan 09, 2011 | HP Lc4276n 42 in. LCD Television
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
Amp sends power to sub at low volume. but when volume is increased speaker loses bass and distorts REALLY BAD. Still has power but clear bass disperses. just sounds terrible at even lower volumes
are the sub speakers ok? if ok then u have a problem with the Amp and the output IC's will have to be checked there cud be a problem with the input card in the amp.
Aug 26, 2009 | Jl Audio 500/5 Car Audio Amplifier
The speaker sounds like it is blown but the volume
could be the sound output IC,is the sound via the headphone ok?
Aug 03, 2009 | Televison & Video
Mono/stereo sound
try the settings button and then hit audio and turn the sound to either mono or stereo or your speakers may be blow
Oct 19, 2008 | Akai LCT3701AD 37 in. LCD Television
Sound won't turn down
Change out your audio cables ,if this does not work some where you are missing ground.or its not connected right.ThankYou for using FixYa. Have a Nice Day.
Feb 17, 2008 | Toshiba 51H83 51" Rear Projection...
TV has a good picture but the sound coming out is nothing but static.
I have the same problem that just develop last week 0 ggod picture but audio is just static Did you find a solution yet?
Dec 26, 2006 | GE 46GW947 46" Rear Projection Television
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
GE (-25001RE2) Audio Conference Logo
112 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
