Question about Samsung Refrigerators
Samsung SRS618DP side by side fridge/freezer, was working butmoved house, during the move the fridge must have been damaged. When power is turned on at wall two loud clicks can be heard from behind the touchpad on the left/freezer door and only the very top right segment of the temp display lights up? i am a refrigertaion techbut cant find any literature on this fridge... please help
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: noise from back of Samsung freezer near ice maker model RS2530BBP
I figured out what was going on with mine and fixed it (without needing to buy replacement parts). In the freezer section, about a third of the way down the back of the freezer was a bulged-out plastic covering, held in place by four screws. The two screws on top are covered by oval plastic that pops off easily with the help of a knife. If you take the screws out, the hard part is that the bulge/cover is still going to be frozen in place. I used an old-fashioned bottle opener/churchkey to gently pry the compartment open. When I got inside, it was easy to see what was happening--the plastic fan was hitting ice that had built up behind this cover. I chipped away all the ice, and presto--no more noise!
Posted on Dec 11, 2008
  • 700 Answers
go ahead and take and hold in the top two button until the unit blinks and resets the controller. Please don't rate this unitl the problem is solved because i can't come back and answer any more questions then. Also if this fix's please rate this solution please. Thanks for usin FixYa
Posted on Jan 01, 2009
SOURCE: Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Posted on Apr 20, 2009
I have a WESTINGHOUSE WSE7000SF side by side
Yes, they can and there will be a wayer line on the freezer door side that will also need to be disconnscted at the bottom.
Sep 21, 2014 | Refrigerators
Led light wont come on
When you remounted the freezer door you might have missed or damaged the switch (button) when you moved the unit. Check that and replace it if necessary. That should fix the problem.
Nov 14, 2013 | Electrolux Vacuums
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
I need to change the water filter in my samsung srs618dp fridge freezer. I have the filter but cannot locate the internal part in the fridge i need to change.
For Samsung side-by-side refrigerators, there are two possible locations. One is in the upper right hand corner of the refrigerator. The other is behind the veggie drawer.
To access the filter, either remove the top glass shelf or the vegetable bin. Turn off the water to the refrigerator. If no filter is currently in use, remove the cap. If a filter is in use, remove the old filter. Turn clockwise to remove the old filter. Save the cap to reinstall if the fridge is ever used without the filter. Note the date when you put in the new filter and place the sticker on the filter. Remove the red cap from the new filter and align the unlock mark with the filter mark on the filter housing in the refrigerator. (Looks like an unlocked padlock with the u part turned 180 degrees from the rest of the lock). Turn the new filter counter-clockwise 90 degrees until the lock symbol (closed padlock) lines up with the mark on the housing. Use steady firm pressure - it will be hard to turn. This ensures a tight seal. Turn on the water line and check for leaks. If the filter isn't leaking replace the shelf or the vegetable drawer.
Samsung support for the SRS618dp is here: .
I hope this helps.
Jun 12, 2011 | Microwave Ovens
My refrigerator samsung model SRS618DP Problem: the freezer is ok but fridge is warm,the temperture is 16c degree
Have you cleaned the dust off of the air filter? I try to clean mine every few months. Mine has a panel in the front on the bottom I remove . Then get in with a vacuum. Hope this will help . If not it cant hurt.
May 22, 2011 | Refrigerators
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram.
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Freezer door left open
Your fridge should be fine, if you have surges that frequently getting a whole house surge protection package would make alot of sense. Surges are especially damaging to electronic circuits found in TV's computers, cell phones, answering machines aell frankly in just about everything. Well worth the charge.
May 22, 2009 | Freezers
Freezer in my kenmore refrigerator isn't cold
Make sure the freezer fan motor is running. The wires may have come off when it fell.
Mar 08, 2009 | Kenmore Refrigerators
Turned power to house off, now fridge and freezer not cooling
you have a showroom switch that may have been turned on. it located at the top in the front middle. if that switch is on the lights will work but the motors will stay off
Jul 11, 2008 | Viking 42 in Built In Professional...
Victory Freezer not working after a move
how long did yu wait before pluggin it in? When laid on its side the freon, and compressor oil migrate. You may have ruined the compressor by turning it on when there was not enough oil in it.
It is best not to set freezers on the side, but if you must, make sure you leave it for 24 hours to allow the oil to settle again before plugging in.
Nov 02, 2007 | LG LRSC26920 25.5 cu.ft. Moving on Up...
Refrigerators Logo
371 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
