Question about Kenmore 23012 Top Load Washer
Noise at end of spin cycle
When machine is at end of spin, the drum vibrates and makes thumping noises as though clothing is not evenly distributed. Does this even when machine does not have cloths inside. Also noticed small spot of oil on floor under machine. What could be cause of drum going out of balance at end of spin? and the oil on floor same problem or new problem. Thank you
  • 5 more comments
  • loumaladams Jun 25, 2008
    thumping at end of spin cycle as if clothes are out of balance
  • loumaladams Jul 06, 2008
    Have the same problem noise at end of spin cycle
  • needarepair Jul 25, 2008
    this washer is noisy! we can't identify the problem. it clangs and bangs and we can't hear ourselves think! My husband has removed the front panel, it has us baffled. It's balanced and it still makes noise when the agitator is removed.
  • Anonymous Aug 07, 2008
    new whirlpool washer. shakes violently in certain part of the rinse cycle. spin at high speed ok. shakes when slowing down.
  • Anonymous Sep 07, 2008
    machine is level
  • blizzard128 Jan 15, 2009
    noisy during spin cycle jumps up and down, always out of balance no matter what size load, Black grease coming out under washer and leaking water.
  • Anonymous Mar 31, 2014
    Machine making a wiring noise but not doing anything, door not releasing
    Novelist:
  • 159 Answers
Sounds like the drive block is defective. The drive bloce is a aluminum part that attaches the drun to the gearcase. If you remove the agitator you will see a large nut on top of the basket. If the drive block is worn yo will see aluminum peices on top. It is very simle to relace. You will need a spanner wrench to remove the nut. With the nut removed lift the spin basket up and out. Remove the block. You will see that the new block will only fit on one way. Tap it down untill it will not go any further, replace the basket, make sure you tighten the nut securly replace the agitator and you will be back washing.
Posted on Jul 12, 2007
    President:
  • 878 Answers
Navy, sounds like you have a worn drive block, common on Kenmores. The drive block sits under the basket. It's about a 5 dollar part. The top of the spin tube has 2 ears that lock into the drive block. If the ears on the spin tube are worn down or the drive block itself is worn, you will get this symptom at the end of the spin. This is not a hard fix...Good luck.
Posted on Jun 27, 2006
Wow...amazing how varied the advice is.
Kenmores last 10+ years average with some lasting 12-16 years.
They need service parts sometimes. Like this one. It needs the inexpensive drive block replaced. Utube has a great video, search DRIVE BLOCK KENMORE.
Posted on Jun 02, 2010
  • raynorsmith Jan 05, 2011
    The Youtube vid was VERY helpful. Thank you!
  • 641 Answers
I don't familiar with your machine, but washing machines has 3 ways to provide a balanced tub movment : - 3 damper pads beneath main support housing on base of machine - Shock absorber springs. - Pistons shock absorber. Check which of these are used in your machine and their status. In case of damper pades you should replace them all. In case of a pistons shock absorbers, it could explain the spot of oil under your machine. Good luck !!
Posted on Jun 26, 2006
I HAVE A FRIGIDARE FEZ831AS1 W/D IT RINSES CLOTHES BUT ON SPINNING CYCLE ITS NOT SPINNING. I HAVE OPENED IT UP AND FOUND SOME PEICES THAT LOOKS LIKE BEARINGS. CAN SOMEBODY HELP ME ON WHERE IT COULD OF CAME FROM.
Posted on Jul 13, 2009
Does anyone know what size spanner wrench I will need to remove the nut?
Thank you for your time.
Posted on Jul 06, 2009
No question in my mind that it is the drive block.  Just replaced mine.  Spin tube "ears" had some how chewed up the keys on the drive block and the tub would not stop when the braking system was engaged.  This resulted in the tub spinning (along with it's drive block) over the spin tube "ears", making the thumbing noise.
Posted on Oct 13, 2007
Oil, rattling noise, nearing 5 years? Main bearing and seal, these machines have about a 5 year life before the seal/bearing gives out. Time to junk it or replace the tub ass'y
Posted on Jul 31, 2007
I had a very similar problem with a Maytag Atlantis. The solution was a new transmission. The oil is leaking from the transmission. Sorry.
Posted on Jun 29, 2007
My Ariston w/d combo has gotten really loud in the spin cycle, so I know where you're coming from. It has a belt drive, and I suspect that the belt is loose. It could also be a simple as the feet needing to be leveled. I'm going to check with a level on mine.
Posted on Apr 20, 2007
There are 2 concrete weights bolted to the drum assembly top and bottom. Make sure that all the bolts are tight. Good luck!
Posted on Feb 06, 2007
  • 164 Answers
I had the same problem with my calypso washer. the bearing went bad, and after 5 years i threw it out. I repair Maytags for a living and it wasn't worth my time and effort to repair.
Posted on Jun 16, 2007
4 Suggested Answers
SOURCE: Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Posted on Mar 07, 2008
mikedurland
  • 481 Answers
SOURCE: washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Posted on Jul 14, 2008
  • 113 Answers
SOURCE: Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Posted on Mar 03, 2009
I have a kenmore 800 series washer that makes a loud slamming noise at the end of the spin cycle. If you lift the lid during the spin cycle the basket slams to a halt immediately. It actually moves the...
Those parts you can check
1/ strings holding the drum were broken causing drum unbalancing when it spins.
2/ Drum bearing also gone. (noise)
3/ 3 slides that located underneath the triangle frame need replaced.
Oct 22, 2013 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
My washing machine makes a very loud banging noise at the start and end of the spin cycle and there is a scraping sound throughout the cycle as though there is metal in the drum. What could be causing...
If you have an older machine it is the un-even load distribution in the wash tub. The wash is not evenly distributed in the wash tub. The wash tub don't spin evenly and wobble instead.
Mar 30, 2012 | Washing Machines
My washer has recently started thumping and banging during the spin cycle. I thought it was uneven weight distribution, but it does it every spin now. And when the spinning slows down it has started...
Hi, . according to your washer problem i m writing solution ,please read and follow it:-
  1. Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
  2. check out this following options one by one to locate the fault in your machine.
  3. 1)Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.2)Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)3)Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.4)Clear thewater pumpfrom obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.5)Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.6)Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
  4. you can get the required partys from
  5. www.repairclinic.com
  6. I hope this will help.
please don't forget to vote me. goodluck.......
Jan 21, 2011 | AEG Lavamat 72640 Front Load Washer
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Washing machine
Jul 14, 2008 | Kenmore 23822 Top Load Washer
on one end there's a clip you hold in then grab the nut end and pull. hope this helps
Feb 15, 2008 | Washing Machines
Noisy spin cycle on washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Dec 11, 2007 | Zanussi FLE1416W Front Load Washer
Kenmore 23012 Top Load Washer Logo
3,705 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
