Question about Brother DCP-110C All-In-One InkJet Printer
Auto cleaning after i've printed 3 pcs of paper, it automatically does self cleaning. and still the magenta color does not print. pls help me. thanks!
Please help me... my printer said unable to clean... ive check it out for paper jam but theres no such thing... i wanna know what happen?
Posted on Oct 23, 2008
I just installed new printer cart light magenta & magenta the self diagnostic shows them as loaded and 100 %. The print quality pattern does not print any color for either of them? No error codes?? I have...
printers will only print black and white unless you change the print settings to be color
before you go to print find the printer settings or options and make the default setting color
that way it will print exactly what is sent from the computer to the printer
Feb 07, 2016 | HP Photosmart C6200 C6280 Inkjet...
Printer problems
HI,
First try to uninstall your priinter and then install it again after you change the catridges..Also make sure you dont have any other printers used parallely..pls try to add your printer through the control panel and then try it once again for taking colour print outs(make sure you select the proper settings in print tab)..your problem will be solved..thank you!!..
Jul 02, 2008 | Lexmark Z33 InkJet Printer
My printer only prints magenta\
A color or photo cartridge is either low, clogged or has run out of one of the basic colors it mixes together to create the colors in your images. The printer cannot print correctly if it lacks one of the basic colors, even if it still contains some of the other colors. The cartridge may also be clogged. The cartridge must be replaced
This may help
You can try to clean the printer head manually. To clean the printer head, remove the ink cartridge from the printer. Moisten a cotton swab by dipping it in hot water or isopropyl alcohol, and then gently wipe the printer head. Do this repeatedly until it softens the dried ink.
For models where the printer head is located in the printer, you can put 7 to 10 drops of isopropyl alcohol in the ink receptacle where the ink flows from the cartridge to the head. Turn the printer to self-cleaning mode. You can also leave it for a few hours or overnight before repeating the self-cleaning mode.
If the print head is located in the cartridge, soak the print head in hot water and let it soak overnight. Dry the print head part using a paper towel and switch it to self-cleaning mode.
If the hot water soak does not work, place the cartridge printer head in isopropyl alcohol and let it soak overnight. Wipe off the soaked area and dry it carefully using a damp paper towel. Turn the printer to self-cleaning mode to remove any dried ink.
For more Help Source... Can You Fix Dry Ink Cartridge eHow
Thanks,
HP Phone Number
Jun 25, 2014 | HP Officejet Pro L7680 All-In-One InkJet...
My paper become polluted by color printing
Hi there!The problem is in you magenta toner cartridge.It happens when a cartridge is refilled or it has damaged PCR.The best way to fix this is by changing the magenta toner.If you have other questions pls feel free to ask!
Dec 18, 2012 | Office Equipment & Supplies
Brother DCP-350C magenta ink won't clean and print quality check shows multiple visible gaps
You have a blockage in the print head and/or feed line from the ink cartridge to the print head. One possible fix would be to make a pad of paper kitchen towel wet it and sit the print head on it overnight. With luck the pad will soak the blockage and draw ink through the head. Give the machine two self cleans and try a print quality test to see if you have made ANY improvement. If no improvement - forget it as the blockage has been there too long.
Oct 30, 2017 | Brother DCP-350C InkJet Printer
We use HP Color Laserjet CM1017; Magenta color is not printing
Dirty laser unit - needs (careful) cleaning internally.
See ' Printing Weak Magenta', 'Printing Light Magenta' for HP CM1015, HP Color Laserjet 1600, 2600, 2605.
All the same laser unit
Apr 14, 2010 | HP LaserJet CM1017 MFP All-In-One Color...
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality
Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print
head. You can start the cleaning process manually if needed.
Clean the print head and ink cartridges if you get a horizontal line in
the text or graphics on your printed pages. You can clean Black only
or three colors at a time (Cyan/Yellow/Magenta), or all four colors at
once.
Cleaning the print head consumes ink. Cleaning too often uses ink
unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause
permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service (see Brother
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
Epson Stylus R230 Light Magenta Not working
Print first a nozzle check pattern, self test which they say. Check your manual for your printer, it should be accessible from that if you dont have any manual, go to the epson website and download a manual. Usually the self test would go like this.
While the printer is turned off, you press and hold down the paper feed button, continue holding it down while turning on the printer. It will print the nozzle check pattern standalone. If you see all the colors then the issue your having is a color management issue, if you do not see the cyan, magenta, yellow, black, light magenta and light cyan from that test; then you will need to do 3 consecutive times of Head Cleaning from the maintenance program in your computer. If you have a windows xp it goes like this.
Click on start go to control panel - printers and faxes -
you right click on your printer icon and select printing prefrences. From there, go to maintenance tab and click head cleaning, go through that cycle 3 consecutive times and see if it improved. Good luck....
Jun 12, 2008 | Epson Stylus Photo R300 InkJet Printer
I960 canon printer
Lift lid ,let carriage stop in middle, un-plug the printer > Remove all ink tanks > Remove print head > Soak print head in > 3 parts very warm water an 1 part ammonia over night. Rinse under faucet with water directly over ink ports, shake out excess water,(if when you shake it out and if color still comes out repeat soaking for another hour or two and rinsing again ,HAD TO DO MINE TWICE) let air dry. (hair drier helps) Cured my problem for a while ,but if not used almost every day, this will happen again, I also use compatible ink tanks. Don'T believe the inks are as good as Canon Ink. But who the hell can afford them. So fill your owe with Canon ink from Canon. Still seems that the cyan always dries up first. Good luck Lestero1
Oct 18, 2007 | Cannon Canon i960 Photo Printer
Brother DCP-110C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
