Question about HP 71 17 in.CRT Conventional Monitor
No signal When my monitor is turned on it displays: NO SIGNAL.However when the pc is disconnected it shows:NO CONNECTION. This seems to suggest it is sensing a connection but just not recieving / displaying a signal It only started when I was forced to reboot halfway through XP home setup and as I dont have another monitor I cant check to see whether the computer is at fault. Looking forward to an answer. Alex
  • HP Master
  • 3,427 Answers
So the screen went dead.
so did you power cycle the PC (is it a desktop?)
then press the BIOS keys to see the VIDEO work now.
if the BIOS is now dead, that is major system problem.
BIOS is first. hit the hot key now.
if the bios works then try F8 as it boots see if safe mode works, my guess is the install is only 1/2 done.
id be all over overheating, fans ,vents, etc, firsts
before id blame any vga card, gee mine has this huge fan on the GPU, too. GFX660, the GPU chips most not over heat too.... ever look inside the old pC
unstated and clean it, ever, or make sure all fans work>./// we cant see inside only you,.
HP 71, CRT, why own this relic?
last guy said it was vintage, (recalls good memories from long ago)?
I can not say why the pc is dead, but it did.
the 71 did not lie to you, i bet.
the old monitor seems oddly enough to be working.
id retire it , CRT can shock you and catch fire.
ever seen the movie, final destination? it's real that.
just one spilled drink and oops.
the CRT is ok, seems so to me. id do tests on it,but...
and half way installed XP , the HDD fails.
why run XP at all, only 1% now in usa, and less every day, the % is falling like a rock due to its zero support now for 3 long years, and a virus magnet.
barrow a monitor.?
the real post here , I bet.
is XP fails to install.
and goes dead, in the process, well gee that is common
the problem is it's lots of causes.
Tell me does booting to KNoppix 7 DVD work or better off a USB stick? work? (live linux try that)
No PC stated,so cant help at all. much.
if knoppix runs good?
then the HDD is bad? or
the XP install disk is bad, is it CD-R or from MS real. (no media stated)
it's one of those 2 things, top caused or.
or PSU bad.
bad memory
or modules inside pC are shorted.
or the PC is overheated for sure Fans packed in lint
dead fans or the heat sink there packed in lint.
that is generic answer, no PC stated by you.
that same Knoopix disk has great disk tester for you HDD.
see it here. smart test is first then hdd tests.
do that first any time and OS will not install.
and win.
http://www.pcdied.com/brick-dead.html#Knoppix
Posted on Jul 29, 2017
  • Anonymous Jul 29, 2017
    http://www.pcdied.com/monitors.html
  • Larry Ng
    Larry Ng Jul 29, 2017
    no PC stated.
    no joy ever.
    10000000 posts now like this, and all fail
    here ,so go to REAL HP and get yelled at for no pc stated, some will say
    "can we see you service tag on you HP PC?"
    what pc, what pc,??? repeat.https://h30434.www3.hp.com/
  • HP Master
  • 10,484 Answers
Your video card either needs the driver for the monitor or it has failed. If you get your video directly from the motherboard without going thru a video card in a slot, then the mother board is at fault and needs to be replaced.
SOURCE: Can't see screen to install diver for HP Compaq WF 1907
My friend just purchase this monitor yesterday. When she plugged it in to the back of the tower she received the same prompt u have mentioned. I was able to repair it because she simply did not realize that I had installed a new graphics card into her pc a few months ago. When u do this, you have to hook your monitor into the area where the new graphics card was installed. You can not plug your monitor into the same onboard card that u have previously plugged your monitor into.
Let me know, if by chance, u did install a new graphics card.
Hope this was helpful :)
Posted on Feb 29, 2008
eduy
  • 22 Answers
SOURCE: Monitor going to sleep at startup
try changing the video card of your computer..
Posted on Aug 27, 2008
SOURCE: HP L1706 LCD Monitor - 'No Signal' Problem
Try to replace your memory.
Posted on Feb 24, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
  • 788 Answers
SOURCE: monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Posted on Sep 12, 2009
No signal on monitor
Sounds like a bad video card or bad monitor. Check the connection to and from the monitor to the pc. If the monitor power light turns on, Then I would suspect the problem to be the video card.
Nov 25, 2013 | Dell OptiPlex 760 MT Desktop Computer
Optiplex 745 monitor goes to sleep randomly
In regards to your issue with your monitor: For a monitor to display "no signal input" there is likely a problem with the monitor making a connection to your input source (yes I know duh). First and easiest thing to fix this is to check your cables going between your computer and monitor, if your computer and monitor start out working and then fail to communicate, there is a good chance that the cable might be coming loose just enough that the connection fails. I might suggest that if you have, as you say another computer, that you try swapping monitors to check where the problem lies.
Hope this helps some.
Aug 12, 2013 | Dell OPTIPLEX 745 PC Desktop
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
Hi! I want to remove the OSD attention from my monitor. How do I manage this? It's necessary to me remove this attention pop out.
OSD popup no signal If you are getting a message that says something like"Check cables" "no signal detected" or something like that,it is likely that your monitor is operating correctly. I would suggestchecking your cables, make sure that the computer is turned on, and if thatdoesn't help, check if your monitor has VGA, DVI, or HDMI inputs. I amthinking that your monitor may be trying to display from the wrong source. This is what a VGA (analog) cable looks like. VGA cables aretypically blue.tgvern_4.jpg
Another common connection that is used is a digital HDMI (left) or DVI(right) connection. DVI cables often have white endconnectors. How your PC connects to your monitor will determine thesource mode you want to use on your monitor. (Obviously this is the cableview but the connection on the monitor itself will look similar.) tgvern_5.jpg
If none of these tips helps, I would suggest hooking the same monitor up to adifferent PC or laptop, and trying once again to get a the display working. Again, make sure that the connection matches the source setting on yourmonitor. If it works on another PC, then your computer may have a videoproblem.
Otherwise, if it still does not work your monitor have a problem displaying viathat connection. If possible I would suggest switching to a differenttype of cable and re-try the above steps.
Mar 20, 2011 | AOC FOVI F19S Monitor
Monitor shows "no signal" and will not start to windows. I've tried unplugging and replugging it. I've switched dvi and vga cables. The monitor turns on, but keeps on displaying "no signal" and then shuts...
the problum is with the PC, test monitor with a good pc,,
Unplugig all cards and ram chips and re try if it works then puging them back in ..Sounds like the pc has a bad ram chip or card some times they just get bad connection,
Mar 30, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Blank display, machine seems to boot ok but display is blank.
If you hear your computer beep once then your system has no problem. If it does'nt show a display, try to check the power of your monitor, if it has power. Check the power cords and also the vga connection.
Nov 10, 2009 | HP Pavilion dv9000 Motherboard
Monitor displays signal cable disconnected
Check your VGA connector (from monitor to PC), namely the pins in the connector. It's pretty easy to bend a pin, so that it doesn't make the connection. If you happen to do this to the connection present pins, then the monitor won't know that it is connected and will just display the message you are seeing.
Mar 15, 2009 | Dell UltraScan P1110 21" CRT Monitor
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
HP 71 17 in.CRT Conventional Monitor Logo
85 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
