Question about AOC 193P+ 19" Monitor
Black space on the right side of the monitor
There is a black space on the right side of the monitor. This happened all of a sudden while restarting the PC after re-connecting to the internet. I've done all that I could do including restarting, changin the internet connection,trying to adjust the position in the OCD menu etc. Nothing seems to work. The start button is barely in view. The icons in the desktop are in position though. Please help.
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
first take off the speakers. you'll see the cable for the speaker. in this slot u can put a screwdriver an pulloff the silver front carefully. then you will see the screws at the top and the buttom. but its better to take off the stand before removing the front. there are 4 screws behind a cover right near the stand. without removing the stand u wont be able to remove the display/electronic
Posted on Jun 11, 2008
  • 33 Answers
SOURCE: aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Posted on Jul 10, 2008
SOURCE: AOC 17" Flat Monitor (silver)
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new  control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
Posted on Oct 18, 2008
  • 4 Answers
SOURCE: AOC LM729 LCD - Go to; bright white lines, blank, computer view and lines, blank. Yeah, please help!
This is an old post but maybe this will help someone else......
I have sold a lot of these LM729's a few years back and now, out of warranty, they are starting to show these same symptoms. I was stumped at first but finally did some real testing on them and found that in every case it it the 1000uF capacitors that are faulty. Look at the board and you will see 2 capicitors, the barrel shaped components, that have 1000uF printed down the sides of them. Both of these should be replaced even if only one is bad because chances are the other will go soon as well. You can usually pick these up for under 2 bucks each at your local Radio Shack. Get ones rated for 35 volts (35V), the ones on the board are 16vols but I usually try to go a bit more robust when I replace capacitors. The rating is just how high the voltage can go so it's okay. They are usually more durable since they are to handle higher voltages. Just take the LM729 apart, remove the power board, desolder the capacitors, clean up the holes, (Be gentle in desoldering them, you don''t want to pull the things, you will pull off and possibly tear the copper foil pad that you need to solder the new cap to) Install the new capicitors minding the polarity, as in there is a MINUS sign on the capicitor and this must go in the hold with the matching MINUS sign. Solder the leads, clip the excess off. Reassemble and you'll probably find that LM729 working just fine! These are very good monitors and very rugged. AOC isn;t at fault for this failure. The Chinese have been making scads of bad capicitors for a few years now. Anymore, if there is an electronic failure it can be traced back to bad capicitors.
Posted on May 02, 2009
AJ _07
  • 51 Answers
SOURCE: Black screen
There is no need to buy a new monitor my friend.
it happened due to inproper power supply so check out all data cables & monitor data cable also.
check out also is there any bent between the pins?
These little one's are soul of the pc's so check it carefully.
Posted on Aug 15, 2009
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
When I bring my computer up there is a black space on the left side. I want the screen to enlarge so I can not see this. How do I do that?
There should be a menu option on the monitor it self. press the menu option and configure the size and position option to adjust the screen display. That should resolve your complication.
Sep 26, 2014 | Acer Computers & Internet
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
I have an acer p241w and half the screen is faded almost to black right side barely visible eventually turns all black. I turn monitor off and right side comes back on but left side is faded to almost...
HELLO I CAN HELP WITH YOUR ACER THE PROPLEM YOU GOT IS THAT CONDENTSATION HAS GOTTEN IN TO YOUR PC OR LAPTOP AND HAS GOT ONE OF THE CERCITS WET TRY THIS PUT YOUR PC OR LAPTOP IN TO YOUR AIRING COBORD FOR 24 HOURS AND THAT SHOULD RESOLVE YOUR SCREEN PROPLEM
Jul 14, 2009 | Acer Computers & Internet
There are 2 inches of black space on both sides of my screen.
There should be a way to go into the screen settings on the set (either from the remote or on the bottom of the screen). From that menu you can adjust the size of the screen, stretch it, align it, etc.
May 04, 2009 | Emprex LM2201 22" LCD Monitor
Monitor goes black but green light on
i think this is the power supply i have same product and problem. i have completely dissembled the monitor and found taht there are three boards power/ input/ video conversion. there are four wires on the right side that go to the inside of the screen. well if you find where to get a new psu the me know
Nov 01, 2008 | Westinghouse L1975NW Monitor
2 inch black on both sides of the monitor (Horizontal)
Hi Bj, Is it an aftermarket video-card? If it is, like ATI or Nvidia, Download the recent drivers for your particular card, Uninstall your Videocard from device manager, then install the software.
CoDoc
Dec 10, 2007 | Dell Dimension 4600 PC Desktop
Analog Dead/DVI OK
Sounds like the video controller board inside the monitor has blown a transistor. They are only about 3mm wide so not easy to spot even if you look closely.
It's a fairly rare fault, though not unknown to happen without reason.
Nov 14, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
AOC 193P+  19" Monitor Logo
120 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
