Question about Bush DVD142RC 14 in. TV/DVD Combo
Dvd won,t eject
Two dvd discs were put in the dvd player on top of each other,now can't get dvd to open or eject
  • Anonymous Dec 31, 2007
    My dvd tray also will not eject, but I only have a single disc inside. When I fisrt pressed the open button there was a loud whirring sound, like a motor spinning without traction, and the tray failed to pop out. After several attempts with both the remote and the button on the front of the television giving the same result I was able to manually slide the tray out to retrieve my dvd. However, now when I press the dvd open button the whirring is very faint and the tray still does not come out. Any advice on resolving this issue will be appreciated. Thanks.
  • mehr_gupta Sep 05, 2008
    I have exactly the same problem!! taking the disc out and putting one in manually isn't a problem, it's just that when you do put one in it doesn't load or work at all!! The button won't open or close the slot and it's really annoying. Any ideas??
  • 1,476 Answers
This is going to require opening the unit and taking the DVD unit covers off. If you feel confident and are good with tools and have a good memory (to remember how it all goes back together), you should be able to get the DVDs out. Just remember to be careful inside the unit, go slow and don't force anything. After the DVDs are out and you have the unit back together properly it should be OK if no damage was done to the laser assembly. Good luck.
Posted on Jun 26, 2006
Sounds like the loading belt has snapped.if you can get the draw open you should be able to fit a new one.
Posted on Jan 28, 2008
Unplug overnight and this reset my get the unit to cop on and be a good piece of equipment, because they all want to be you know?
Posted on Nov 26, 2007
I have this tv and had the same problem but what fixed it for me is putting a knife in there and the dvd ejected. The problem was the dvd was off line from the plastic outside the tv and it was just hitting the tv. So if you put something very flat in there it might move the dvd off to the side and slide right out.
Posted on Apr 09, 2007
Where is the DVD emergency eject hole for DVD724?
If there is an eject hole, you should be able to see it on the front of the drive.
Dec 08, 2017 | Philips DVD724 DVD Player
Blu ray player won't play or eject disc
If you want to eject the CD you need to look on the front of the Blu-Ray drive for a small hole, about the size of a pencil-lead. If you open a paper clip and insert it, it should pop the drive open for you.
Mar 06, 2013 | Televison & Video
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
REGION 2 DVDS ON REGION 1 PLAYER
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 29334
4) When it works a 1 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
Enjoy
Jul 18, 2009 | Samsung DVD-1080P9 DVD Player
Dvd recorder doesn't eject disc
Yes, I'm having the exact same problem -- I can't eject the dvd that's in the player right now either manually or remotely. It plays fine.
Sep 23, 2007 | Televison & Video
Bush DVD142RC 14 in. TV/DVD Combo Logo
1,611 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
