Question about HP Office Equipment & Supplies
My HP Photosmart C6180 All-in One Series prints out a Fax Log after each Fax sent, How do I change the setting so that it prints a Fax Log only on request
    President:
  • 1,901 Answers
Press the Fax Menu button twice to get to the Fax Menu to select or change Fax Options. I didn't see Fax Log in the manual, but I think they refer to it as a Fax Confirmation.
The only reference I saw in the manual was this:
"Note If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes."
Posted on Oct 20, 2008
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Does the C6100 have fax history printout capablity?
Hi
Yes, Photosmart C6100 series does have the capability to print the fax history i.e. known as fax log, but its is only possible if you have not performed any resets recentlyt
How to print that?
Please follow the following steps to print it
1. Press the setup button on the printer
2. Go to the option that says 'Print Report'
3. Press Ok on print report
4. Scroll down using the arrow keys and go to fax log
5. Press Ok on fax log
6. This would print the history
All the best!!
Oct 29, 2010 | HP Photosmart C6100 All-In-One Printer
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
Image on fax send report is off
this is a default setting of the printer and fax settings... it will not impact the functionality of the unit but if you wish to change it then press the set up button on the printer go to print reports press ok and with in the print reports menu you should find image on fax send press ok and switch it to on press ok and exit out of the set up menu
Mar 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP 7280 can't find the fax log
On the printer itself hit the setup button (the one with the little wrench)
Then go to print reports and press ok
Then to fax log and press ok.
Jan 15, 2010 | HP Photosmart C6180 All-In-One InkJet...
My photosmart hp C6180 keeps saying printer alignment failed and it will not print anything with black ink. I have replaced the black cartridge 3 times. What do I do? It will print all the other colors...
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
Unfamiliar with my friends FAX machine
Assuming that that the machine has a live telephone line plugged in and that it is functioning properly, then you can place your document either face down on the glass or face-up on the feeder (if multi-page). Simply use the numerical keypad on the printer to dial the fax number you wish to send to (don't forget a 1 if long distance) and then press the [Black] button under the START FAX heading. That's it.
You can also send through the software (fax from Word, etc.) by going to File --> Print and choosing the HP Photosmart C6100 Series Fax from the list of printers... but printing a hard copy may be the simplest way for you.
Dec 31, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart C6180 all-in one
Your manual can be viewd / downloaded / printed here, directly from HP:
http://h10032.www1.hp.com/ctg/Manual/c00753187.pdf
The fax setup section starts on page 33.
Apr 22, 2008 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c6180
no solution, but that's what mine did to! What is with the pink ink?
Apr 09, 2008 | HP Photosmart C6180 All-In-One InkJet...
252 people viewed this question
Seeker5211
Seeker5211
