Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP7410 just displays "HP Invent" when turned on
I turned on the printer, and all that happened is the "HP Invent" logo displayed in the window.  I tried turning off / on the printer, unplugging and replugging all of the plugs, and reset the power strip.  The printer worked the day before, though the scanner feature would not work unless directly wired to the PC.
Printer is 30 months old; and other than scanning, has no problems.
    Sergeant:
  • 352 Answers
Hi cbarsetti, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
Hp7410 Wont turn on and function, power light doesnt come on and the HP Invent Logo keeps cycling on and off
you might want to check to see if the wireless for this machine is connected to main pcb, if so, disconnect, you will have to pull off the back of the machine, requires #10 torq bit, cable is a 4 wire cable, it travles from right of machine to left of machine, the only other cables that travel from right to left, is speaker cable, only 2 wire, and then the doc feed cable, which has 8 to 10 wires on it. if problem still continues, then main pcb will need to be replaced.
Sep 23, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP Laserjet 4345MFP Backlight on printer display does not light. Counts up the 256MB memory then HP logo (3 sizes) appears (just visible) The 3 lights keep cycling on the display. Thats it, does nothing...
HP Laserjet 4345MFP
The 3 lights keep cycling on the display. Thats it, does nothing else.
It has been left overnight and continues to display the logo and cycling 3 lights.
Rear DC Cont Fan is turning. No other fans or activity with machine.
When ADF/scanner/mfp or hard disk are disconnected it does recognise this and throws an error and asks for reboot.
I have tried cold reset, nvram init. and hard disk init. but no difference.
Your thoughts?
Aug 27, 2010 | HP LaserJet 4345mfp Printer
My hp7410 will not go on past the hp invent screen even though it is plugged in and was working
disconnect from the power source - ie surge protector or power strip and connetc it direct to the wall outlet
Jan 04, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer stopped working.
Printers are cheap and not worth fixing it sounds like you have a common problem involving the internal CPU in the printer to have it repaired it would cost twice as much as to buy a new on
Sep 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Display screen stuck on hp invent - buttons don't work
This is apparently a common problem with this model, but HP has not offered any help with it. Mine did it a few weeks ago and I found the solution in another thread on fixya. Follow this link and then open the back of the printer and disconnect the wireless card as described by Maggix. It will kill your wireless capability but let the printer start working again.
http://www.fixya.com/support/t648531-hp_7410_all_in_one
Jan 01, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 Display HP logo and Invent
Hello.
I'm afraid this one is a critical issue. If your product is in warranty or out of warranty , it would be better to upgrade to a newer model as this is a serious flaw in the printer.
all the best.
Sep 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Looks like printer is on, but it won't do anything
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Thanks
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
110 people viewed this question
Ben Johnson
