Question about Optus Computers & Internet
Internet and phone connection
My modem is connected directly to my phone line.my pnone when being used has a crackling sound every ten or fifteen seconds.is it the way i have connected the modem?
  • 507 Answers
It's usually like that since you're still connected, that's the sound of handshaking, your computer is getting and receiving data.
you might want to get a dsl to avoid this.
Posted on Oct 20, 2008
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
Tip
My Internet connection so slow?
<p>The type of Internet connection you use is the most important factor in determining your connection speed. The three most common ways to connect to the Internet from home are dial-up, DSL, and cable. If you have a choice, cable is usually the fastest, but both DSL and cable are faster than dial-up. <br /> <p>Many Internet providers also offer Fiber Optic Service (FiOS), which connects to the Internet using light over an optical network. In your home, you still connect your computer through copper wiring. The advantage of FiOS is that it can provide higher speeds than traditional copper wire connections such as DSL or cable. Some Internet providers offer multiple options, depending on the area you are in. More populated areas are more likely to have FiOS available. Check with your phone company or Internet provider for more information.<br /> <p>If you use a dial-up connection, there are a couple of good ways to optimize your Internet speed. First, use the fastest modem you can. The fastest modem you can use will send and receive information at a rate of 56 kilobits per second (Kbps). You won't get a full 56 Kbps speed most of the time, but with a good phone line, you should approach at least 45-50 Kbps. <br /> <p>Second, make sure that your phone line is in good condition. If the telephone wiring in your home or business is old or deteriorating, you might be picking up stray signals or cross talk from other phone lines. These problems will slow your Internet connection because the modem will have to send the same information over and over until it's transmitted without interruption. Check your telephone wires to be sure they aren't damaged, frayed, or twisted around power or other telephone cables. If you notice crackling in your phones, you might want to contact your phone provider to have them check the lines inside and outside your home to make sure they are in good condition.<br />
on Dec 03, 2010 | Computers & Internet
Internet signal keeps dropping
There's a lot of possiblities here.If you have a DSL/dialtone lineshare,listen for noise on the line(humming,crackling static,dropped calls).If you have a dry loop(DSL only),connect a phone in place of the modem and see if it has an "intercept" message(like "you have tried to call a number out of your service area" or something like that).If it does,you can use a phone to check the line when the DSL drops(don'touforget to put an inline filter on it).If the DSL light doesn't go out when the Internet light does,it is NOT a problem with the physical line.This would be an issue with the modem or the equipment at the serving end.( I am a DSL tech,and spend lots of wasted time diagnosing and trying to fix problems that are beyond my reach(central office server issue) or that I didn't need a dispatch for(it is cheaper to send a new modem than to send a tech).
Jun 02, 2012 | D-Link DSL-2640R Wireless G ADSL2 Modem...
I am using Nokia 6070, while trying to connect this pnone into the System for browsing internet, not able to connect.System is showing "Does not recongnize".But PC suit has been installed for 6070. But...
Supravat,
First of all connect the phone to the PC through the USB cable Fire up Nokia PCSuite. Does the Suite recognize it and show it connected. You say No. In that case you have to configure from Settings the phone to be read by PCSuite. Once recognized, then you must click on the Internet option in the Suite. here again you will have to configure the modem settings shown by a geared wheel. Set the modem as Nokia 6070 and the service provider as whatever your service provider is. click OK and then click on Connect. It will take a few seconds to connect and when connect the Internet portion of the suite will minimize on its own and you can then close the PCSuite box. And you are ready to browse.
Dec 10, 2009 | Nokia 6030 Cellular Phone
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
Wireless to my laptop
Hi there.
You can buy just 1 device nowadays a wireless modem router, this will connect directly to the cable or telephone socket and give wireless access almost straight away.
May 28, 2009 | Gateway M305CRV Notebook
I have a modem im hooking up 4 pcs to. Where does the phonelineGO
When I hook up my Linksys the way it should be hooked up I loose my internet connection on my computer. Help!
Dec 31, 2008 | Linksys Cable Modem
New computer running slow
if you are using dial up, you shud not have a modem.. modem is just for DSL connection
if you have a modem probably you are using a DSL connection
DEFINITION:
dial up - connection using a phone line with internet connection; cannot use fone while on internet
DSL/modem- connection using a modem plugged in with computer and fone line; able to use fone even when on internet.
Jul 10, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
My internet keeps dropping out
possible reasons:
Dial up:
  • phone line problem.especially in wet weather,crackling on the line ,call the telco.
  • modem\router on its way out. connect directly to the modem and try it .
  • settings for idle time before disconect needs turning off, (set to 20 minute by default)in most cases.
  • if you have call waiting ,turn it off ,as it can kick you of the net when a call is trying to comes in.
if you use ADSL and/or wireless :
  • some of the above and
  • some USB dongle are prone to drop out,
  • try using a Lan cable
  • brick walls and other hard surfaces can interfere with the signal if you are away some distance from the wireless router.
  • cordless phones can cause problems, keep them away from the modem\wireless router and wireless dongle, or adapter in the pc/laptop
good luck with this and let me know how it goes
Terry
Apr 02, 2008 | Computers & Internet
Problems with my new TP-Link 108 wireless ADSL2+ router modem + splitter filter
sounds like you are using a splitter...does your modem run off a splitter without a dsl filter on it?
Feb 21, 2008 | Computers & Internet
Computers & Internet Logo
51 people viewed this question
Top Optus Computers & Internet Experts
gaucherre
ray gallant
Bill Boyd
Are you an Optus Computer and Internet Expert? Answer questions, earn points and help others
