Question about Whirlpool AWM5125/1 Front Load Washer
My washing machine has a bad smell and wont work
Where is the pump on my wfs107aw whirlpool washing machine
    President:
  • 1,653 Answers
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
I have a 14 year old Whirlpool washer. Yesterday my wife was doing a load. She heard the machine had stopped so she went down to the basement to throw the clothes into the dryer. She smelled a strange...
Most washing machine pumps are mechanical and would leak if bad. I don't think the smell is from the pump... more likely the motor.
Probably best to put the repair money towards a new washer unless you do the work yourself.
Jan 03, 2011 | Whirlpool Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Whirlpool wash machine stopped spinning , motor stopped water did not leave- smelled of rubber
pump/or basket not spinning causing the belt not to turn thats the reason why is smells like rubber check pump and basket for free turning
Dec 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Wont drain burning smell
if it smells electrical then it is the motor and just because you replaced it months a go that dont meen anything i have seen them come off the shelf and be bad not saying ddty that this is your issue but it sounds like it a bad solinoid chances are very slim I would look towards the motor to find out when machine quits lean machine back on the wall so it dont fall on you and put your hand on the motor if it is hot then it is over heating and needs to be changedplease let me know what you guys find and if i can help you in any way
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
341 people viewed this question
Dan Webster
Dan Webster
Sal De
