Question about Refrigerators
Ice dispenser does not work on kenmore side by side refrigerator model #106.53652300
  • 4 more comments
  • Anonymous Oct 20, 2008
    ice maker is not making ice, repairman replaced electronic eye, but it's still not making ice.
  • Anonymous Oct 24, 2008
    Ice dispenser does not work. Water works fine.
  • Jerry Jan 01, 2009
    The ice maker makes ice, the water dispenser works but the ice "dispenser" does not work on either crushed or cube setting. Every time you try to dispesne ice it shuts off the fan in the freezer and when you let go the fan comes back on?
  • Anonymous Feb 10, 2009
    Same issue. Motor is not turning, but I cannot determine if it is because of the motor, board or some other sensor
  • dwdlcc Feb 13, 2009
    Yep, Same problem. BTW How do you remove the cover??
  • Anonymous Feb 17, 2009
    Same problem. Repairman offered "new auger" for $350 with 30 day warranty. So, I scoop the ice by hand.
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
SOURCE: New Kenmore Elite ice dispenser not working but water is
ther is no ice comming out, it suddenly stopped. Kenmore Elite I dont know whats wrong with it I know that water may not be getting into it but how do I solve this problem
Posted on Jul 13, 2008
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Sep 19, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot water dispenser stopped working. Ice maker works. What could be possibly wrong?
On the rear of your refrigerator there is a dual water control valve. One side for ice maker and one side for water dispenser. I believe your side for the water dispenser has failed and they come as a set. Send the Kenmore model number and I will find you one. The number will look like this, 326.256489 for example only. Found near the bottom of the fresh food section door. Thanks, Sea Breeze
Nov 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Automatic ice dispenser on Kenmore side by side freezes up
Probably the trap door where ice dispenses out is not sealing tightly causing frost buildup
Sep 29, 2017 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Refrigerators Logo
384 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
