Question about ATI RADEON 9200 Graphic Card
Help me about three month ago, my hard disks was corrupted and i had changed the hard disks.but my laptop do not have the graphic card anymore. i'm using compaq presario b1900 with vista as the OS.the previous graphic card i used was ATi Radeon.so what should i do
  • 13,433 Answers
Vista doesn't support ati 9200 anymore. you need to upgrade your card or go back to windows xp where the card ati radeon 9200 is supported. if that is your card.
but if you got presario b1900
goto the hp page here
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=321957&prodSeriesId=2512115
or here
http://h20000.www2.hp.com/bizsupport/TechSupport/Product.jsp?locale=en_US&taskId=135&prodTypeId=321957&prodCatId=82710&prodSubCatId=212728
select your model from the list and you will get eventually to the driver pages.
Posted on Oct 20, 2008
My laptop asus g1s i need password bios for it I'm not putting it but it show after i fixed i problem in Graphics card
you may have had a bad graphics card. if it workes after changing the graphics card, the bios is still locked, but not for use when powering on the system. without a regular bios password, you cannot enter the setup from the startup menu. with a bios security password, you will need a password to unlock the screen preventing it from starting, this password can chain to a hard disk password unlocked by placing the system security password, which will then provide a prompt for the hard disk password. :) one locks the setup for the whole system. one locks the system from starting up, and one locks the hard disk from being read. there are three. without knowing the password, if the computer will not start and load your system, ie windows mac osx, you can have someone retrieve the password, or change the motherboard. if it starts, most people don't worry about it. if it cost more to have someone resolder the bios chip, replace the main or motherboard. if it starts and runs, use it and don't worry about it. :)
Nov 21, 2015 | ASUS Computers & Internet
My system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
What is the reason of very slow speed of laptop hp 6710b intel core 2 duo
Apr 20, 2013 | Computers & Internet
How do i speed up my laptop
Mar 21, 2013 | Computers & Internet
My computer is slow
Feb 07, 2013 | Everex StepNote NC1502 Notebook
My TOshiba satelite pro L300 in not continuing to windows,the screen is black i think its hanging up..were trying to reformat it but its not successful.I dont know if it had a bad sector in hard disk. but...
Hi
When a computer powers up the basic control program (BIOS) first addresses the graphics, then the CPU, then the memory, then the hard drive, then other devices.
If you see nothing at all on the screen, then it is probably a problem with the graphics card.
Check the lights on the front of the laptop. If you see a power light but no activity on the hard disk activity light, then the boot is failling at the 1st stage, before it even reaches the hard disk stage. this means a graphics problem.
If the hard disk was preventing the computer from biooting you would see the first 3 parts of the boot procedure on the screen before it stops at the hard disk stage.
Remove the battery. Connect the power cable without the battery and try to boot. If it boots, the battery is the problem.
Connect a desltop PC VGA cable to the laptop's VGA port and connect it to a desktop PC monitor and send the image to the external monitor by pressing th Fn key simultaneously with the Function key with a picture of 2 monitors (normally F5, F6 of F7). If the image appears on the external monitor, the graphics card is ok.
If the graphics card is OK, then the problem will be a faulty LCD Panel, LCD Panel Power Inverter or LCD Panel Cold Cathode backlight. If not then the problem is the graphics card.
Ask a technician to test and replace any of these faulty parts, if necessary.
If it is the graphics card, then the repair is either Ball graphics Array Reflow or Reballing, both of which can be expensive, have a marginal success rate and the fault can reoccur after repair.
Only a specialist with an Infra Red workstation can fix the graphics card,. typical repair warranty is 3-6 months. If it's too expensive to fix, it may be better to buy a new laptop.
I hope this helps.
Aug 24, 2011 | Toshiba Satellite Pro L300 Notebook
Second hard disk drive not detected???
What was the error on the blue screen? need the error and the error number. I would check the cable connecting the hard drive to the motherboard and replace it. also try plugging it into a different plug if its sata
Jun 16, 2009 | Computers & Internet
IBM Thinkpad A20m model 2628
You can download the software known as Active boot disk. With this you can create a bootable cd to run a chkdsk with the f and r command to fix and recover errors on disk. you can also explore your comp and copy files to an external disk. If after the system boots normally after chkdsk you might have a problem with your HDD get it replaced before it crashes again
Jan 20, 2009 | IBM (08K3261) for ThinkPad A20P, A20M,...
Laptop Gateway mx8711
Gateway laptop is really ****.
I bought Gateway MX8711 in March 2007, after 6 months i use it...the hard disk failed.
Gateway replaced a new Hitachi hard disk for me but not more than 8 months and it failed again.
Gateway told me that i have no more warranty because the repair warranty is only 90 days.
I bought this laptop and use it not more than 2 years, the hard disk was failed twice.
Usually Hard disk manufacturer provided 3 years warranty for the hard disk. The manufacturer year of the hard disk is May 2007....they should able to help because the har disk not more than a year being used...but they don't. This is really bad customer service and not fair to the buyer.
I will not buy any Gateway products anymore....i swear.
Jun 24, 2008 | Gateway MX8711 Notebook
Compaq presario 700 Black screen
There might be several reasons, hardware nor software/operating system, but most probably from the hardware. Can be the graphic card (if you can notice the hard disk work well - from the sound), can be the hard disk, or even the mother board. We have to go through the symptom.
Since it is still new, the best solution is back to the seller for guarantee.
Feb 27, 2008 | Compaq Presario 700 470024-192 Notebook
ATI RADEON 9200 Graphic Card Logo
148 people viewed this question
Top ATI Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Computer Links
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
