Hello fellow experts now this is abit of a challenge one. On any incoming calls or while talking, the phone drops its calls as in it (cuts out) then it restarts and lossing the calls altogether. Need a solution for this.
Thanks soldierruel.
Comments:
Jul 09, 2006
- Thanks but i've done all the firmware update and its still the same. We have like 50 Motorola V3 that has the same problem. Silly girl do you have an email address or msn we could work together on solving problems.
-   I have fix many razrs from dropping calls simply by putting a few layers of tape on the bottom right side edge of the battery causing a tighter fit.
Good luck-   Guest
Jan 04, 2008
-   I fixed many razrs that were dropping calls simply by putting a few layers of tape on the right hand bottom edge of the battery, causing a tighter fit. Good luck.
It could be a firmware issue. Have you done anything to the phone's software recently? any physical damgage? battery ok? Either fixed by a firmware upgrade - take the phone to a moto service center to run a firmware upgrade, or by a flashing/flexing of the phone, check out this thread: http://www.fixya.com/problems-solutions/...
Just keep in mind that if you screw around with it it might void your warranty if you have one, so try first with motorola.
Good luck
Was this helpful?
Yes
No
Solution #2
posted on May 12, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Reseat the SIM card. I had the same problem and now it works fine.
suncom phone need it for t-moble , my brother gave me a phone b-c my other one is broken, its a...
(More)
suncom phone need it for t-moble , my brother gave me a phone b-c my other one is broken, its a suncom phone and i have a t-moble contract
Get no sound through the earpiece of razor v3, can turn speaker on and get sound ok. Started with...
(More)
Get no sound through the earpiece of razor v3, can turn speaker on and get sound ok. Started with loud crackling in the earpiece on 2 calls, since then no sound.
my cell phone screen went blank after i dropped it. i can make/receive calls, i just cant see who's...
(More)
my cell phone screen went blank after i dropped it. i can make/receive calls, i just cant see who's calling and can't get to my address book or text messages. can u help?
