Question about Maxtor OneTouch II external hard drive 500GB 7,200 RPM - FireWire & USB (E04W500)
Help!Help with external hard drive?
Help with external hard drive? This morning i dropped my external hard drive on the floor and now it wont register on my or anyone elses computer.
it turns on and everything but the drive doesn't show up on the computer desktop.
is there any way of fixing this? apparently data recovery is like$300...if anyone knows any places in melbourne where it's cheaperplease let me know asap.
thanks
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    nope..that is what it costs...and that drive is toast.
    Problem Solver:
  • 4 Answers
Your disk drive is a delicate instrument, it will react negatively if dropped on the floor.
However what you might try all be it rather radical in this age of micro fine technology is. take a deep breath and sit down. Take the disk drive in your left hand with the edge of the drive that struck the floor facing away, make a fist with your right hand and strike the opposite edge with with almost equal force.
The reason behind this is simply that when you dropped your drive on the floor the heads got jammed either into the disk spool or out side of it,
If you have to pay $300 for disk recovery you cannot be doing much worse than trying this before you have to.
Posted on Nov 30, 2008
Dropped my Transcend Storejet25p 5oo gb on floor !
Your hard drive is damaged beyond repair.
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Oct 18, 2012 | Transcend StoreJet Computers & Internet
How can I recover my files after I drop my external hard drive?
First of all - STOP using your WD drive immediately! If you continue using the disk drive, you significantly increase the risk that the files you want to recover will be lost forever due to overwritten. Every new file or action will take up more "free space" and reduce your chances of retrieving your deleted files from WD. So really, you need to act quickly.
The next step - get a good HDD data recovery software to retrieve the data as most as possible.
Learn more from: http://www.western-digital-data-recovery.com/
Jun 22, 2012 | Western Digital My Book Essential 1TB...
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Dropped my external hard drive
danielhighto
Unfortantly if you dropped the drive then most likely you killed the drive because it messed up the read system in the drive. Now the case its self should be fine so you might keep it in case you ever need an extra drive encloser.
Sorry for the bad news
Issken
Jan 14, 2010 | Computers & Internet
Hard Drive Dropped
Turn off your computer and then plug in the FreeAgent external drive. Then try turning your computer on, it should read.  If it doesn't I would go to the Seagate website for troubleshooting.
Jan 31, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I can't open or view my data in Western Digital hard drive
You have to be more specific in order to receive help.
You said: "Last week my hard drive was fallen down on the floor.
Was it in a desktop or laptop & how did it fall on the floor? Did it jump out of the computer or did you drop the computer? What do you consider to be a hard drive?
Nov 23, 2008 | Western Digital External USB 2.0 80 GB...
External Hard Drive Not working
no worries..unplug from computer..
remove software
go to the wdc.com website, get new drivers
re install
try it again
check your computer warranty here 4 FREE
make your office babysafe.
Mar 28, 2008 | Western Digital 500GB My Book World...
Slightly dropped seagate external hard drive, recover data??
please use stellar phoneix software
that will do your job surely
Mar 16, 2008 | Seagate 160GB 3.5" External USB Drive 160...
Lightly Dropped Seagate 100GB External Hard Drive
Unfortunately, this probably means the read/write heads were jarred and can no longer function properly. That's usually fixable, but it's a very expensive fix because the parts are inside the hard drive and the data surfaces are very delicate... Most people are better off simply replacing the hard drive unless the data is absolutely vital.
Dec 06, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Computers & Internet Logo
113 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
