Question about Akai CFT2490 24" TV
Edges of Picture & Text Sloping
My Akai Tv is about 2 years old. Recently the edges of the picture curve similar to this ) ( any text on screen appears slanted and any part of an image ( walls, doors etc) appear curved. Turning the unit off & on several times fixes it temporarily. Any Idea"s
The picture on our Samsung dynaflat is no longer filling out the whole screen. The sides on the left and right bow inwards. The picture is blurred and distorted. At first this was temporary, but now it stays this way. When we "smacked" the top of the set, it was OK for a minute, but then went right back to the bowed image. This t.v. is only about three years old.
Posted on Dec 31, 2006
    Novelist:
    Champion:
  • 275 Answers
I agree with techman.Looks like a dry solder or overheating in the Pion cushion correction ckts. Beast let a pro technician take a look. Nothing much u can do. Pravin
Posted on Jun 26, 2006
    President:
  • 3,130 Answers
This mis probably a cold solder connection in the horizontal circuitry called the pincussion. Theres a couple of coils and resistors that overheat from time to time and the solder connections get loose. Not really for a handiman has this tv has hi vboltage inside even when turned off. Shouldnt cost an arm ans a leg to fix if the repair shop knows what they Are doing. Good Luck
Composite output has ghosting around the video (sort of an auro around all images on screen, including text and video). dvd menu also has this problem, so i verified that it is the output of the recorder...
Try reducing your sharpness value on either your TV or the player if applicable. Also disable any edge enhancement or "DVE" modes on the TV if applicable.
The easiest way to adjust sharpness control by the naked eye is with a calibration disc. Alternatively however, just for sharpness if you have a screen full of text and/or lines do the following;
Reduce your color/saturation value all the way down...this will make the picture black and white.
Then reduce your sharpness control until the "ghosting" effect or any additional white lines on text edges and line edges disappear.
Then you can return your color/saturation value back to normal.
Hope this helps!
Jan 12, 2011 | Toshiba DR4 DVD Recorder
When text appears on screen, the letters overlap on R/L sides
Ur tv have a convergence problems,the 2 STK convergence ICS are defective.Try website like Tv repair World.com.They sell the rebuild Akai/Samsung the whole convergence board.They used the same convergence board.
May 07, 2010 | Akai PT4298HD Rear Projection Television
I have a Samsung HL-T5676S DLP TV and the picture just recently started to look curved. In the middle of the screen it's straight but on the sides it starts to curve up. Any idea of what could be causing...
make sure you do not have anything sitting on the top of this tv. I have seen this on my tv by just gently putting pressure with my finger on top the screen starts to curve up at the edges.
Jan 14, 2010 | Samsung HL-T5676S Television
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Won't display tv and there is a black box during dvd play
It sounds like you have the closed-captioning set to "text" mode. When set this way, if captioning is present the set clears the area where the text goes. You don't see the box on channels or programs where captioning isn't being used. On most TV remotes a single button controls captions, so it's easy to get into text mode without knowing it.
Apr 04, 2009 | Toshiba 46H84 46" Rear Projection...
Hi, have a 50 inch rear projection Mitsubishi. The problem is that the picture is curved and some of the words around the edges are doubled. Its most noticeable when watching sports because the score board...
power transistors in the convergence circuits on this series TV go bad after several years, making the wavy lines around the edge of the screen and 'doubling' of the edges of the text in varied colors which do not converge. Professional repair is required unless you are brave enough to tackle the project yourself and follow some rather simple instructions, buy a few tools from Radio Shack, and save yourself about $500 bucks...which I did on my own 42" Panasonic rear projection set.
Feb 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Orlando Vilanova
was thier a big black box like over the picture and you could just see the edges if this is the case you have the closed caption turned on it's called a text box. if not describe it to me a little more also let me know if it does it on all inputs with dvd,vcr, satellite or cable.
Mar 17, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Screen is distorted on the top and bottom
Loose connection on convergence board, you could tapp and should go back to normal, find loose conn. and solder back.
Sep 09, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Akai CFT2490 24" TV Logo
214 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
