Question about Uniden TRU8885-2 Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
    President:
  • 3,130 Answers
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Posted on Jun 26, 2006
    New Friend:
This is Registration process as directed in the menu but its not working please suggest another way
Up to 5 handsets can be registered to one base. The original
handset is pre-registered to use. Additional handsets must
be registered to the base before you can use them.
To register an additional handset,
1. Press
P
and
to select
SETUP HS.
2. Press
P
and
to select
REGISTRATION.
3. Press
P
and
to select
YES
or
NO.
4. Select
YES
and press
P
to enter the registration
procedure as below:
1. Place the unregistered cordless handset on the
charger.
2. Press and hold
v
for 4 seconds on base.
3. Release
v
once IN USE LED is flashing.
4. A confirmation tone is generated if registration is
successful.
HANDSET X
is displayed where X denotes
the number of handsets and the phone goes back to
idle.
Posted on Jan 31, 2014
    New Friend:
Ragistration problem my mobil number0096541057138
Posted on Apr 26, 2013
My citrion c8 boot is locked. The side door have to opened and shut manually. The passenger door doesn't lock when locking drivers side. The hone doesn't work. Please can anyone help?
sounds like a fuse, check EVERY fuse before ruling it out as the problem. anything else is going to the garage and they will charge you if it ends up being a fuse
Jul 13, 2013 | Cars & Trucks
Black screen!
Does you have Windows 8 Installed?
If Yes, then you installed a cracked version of Windows 8 which caused the problem. Buy The Original One which will solve the problem
Or Else Please Mention The Device Name and Specs You have problem with.
May 06, 2013 | Computers & Internet
Help! My Laptop Acer Aspire One stuck at window logo loading Anyone please, help my acer aspire one stuck at window xp logo loading. I try everthing in F8 button, it didn't work, even in safe mod
oh a fun one. Reset your bios to defaults. if that doesn't work then try a windows disk boot up. if that doesn't work you're screwed.
if you want any of your files from the computer first pull out the hdd buy a cord and transfer them to another computer.
Sep 07, 2012 | Acer Aspire One PC Notebook
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me abigail@nkaditelecoms.co.za
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
I received the Rohl soap/lotion in-counter LS550 pump assembly because the pump I have with this dispenser (LS650) doesn't pump. But I do not know how to take off the old assemby and install the new. ...
Hello, Thank You for using FixYa. I will be helping you today.I called rohl and was told the only thing you had to do is look under the counter and you will see a nut that is holding the pump down. Remove the nut and lift the unit up and out.This was from rohl. Hope it helps
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Home
Dishes are left with a white film that doesn't
Hello, Thank You for using FixYa. I will be helping you today.Please read this http://kitchenaid-internal.custhelp.com/app/answers/detail/a_id/3854
Jun 14, 2011 | Maytag Dishwashers
Check engine light is on and stays on. also rightside window doesn't roll up or down and the right mirror doesn't work.
Regarding your check engine light, you'll need to hook the car up to a scanner to find out what codes are stored in memory to see what's the problem. As for your window and mirror, it sounds like it's the (SAM / computer) in your f/r door. Anyone with the mercedes benz computer (Star diagnostic system) would be able to further diagnose this issue for you before changing the wrong part. If you're in the NY area I'd be happy to diagnose this for you.
Please don't forget to rate my answer.
Jun 13, 2011 | 2003 Mercedes-Benz S-Class
ZENITH/INTEQ MODEL IQB36B44W OWNER MANUAL
LG`s home page doesn`t show an e-mail address but heres the next best thing. 1-800-243-0000 be sure to have your model number ready when they answer, hope they still have one
Nov 27, 2007 | Zenith IQB36B44W 36" TV
Uniden TRU8885-2 Cordless Phone Logo
2,280 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
