I have a DPTV335 that seems to have a short in the blue crt. When I turn the set on I see a blue arc in the tube. All three CRT's won't light up except for the faint glow (heater). Is that normal?
I removed the blue CRT board from the tube but the red & green still did not light up.
Quesitons 1) What is the best way to bypass a shorted crt to test this set? I read somewhere that all three crt's need to be connected or the set will shut down. Is that correct? I don't want to do further damage by powering up the set without the blue crt circuit board connected.
I also tried to move the blue crt to my old set (PTV835)...to test it....Dumb move I guess...Now the PTV835 set is dead also...It was working before I put the faulty CRT into the set but now all three cans are also dead.
My guess is that the bad CRT somehow shorted out the something in both sets.
Question 2) When a crt shorts does it typicaly shut down all the cans?
Question 3) When a crt shorts - what other circuits get damaged? I'm trying to figure out where to go from here.
I just replaced the convergence chips on my Philips 60'' projection TV and forgot where all the...
(More)
I just replaced the convergence chips on my Philips 60'' projection TV and forgot where all the wires go? My Dad thinks he has it right, but the picture is red & blue & the captioning is shadowed. Can you please help?
It appears that the white is over exposed and bleeds into the darker colors.It started after my...
(More)
It appears that the white is over exposed and bleeds into the darker colors.It started after my in-laws left it on all nite with the cable turned off.
