Question about Kenmore 22422 Top Load Washer
Kenmore Model 24642300
I've had this Kenmore top-loader washer for about 3 1/2 yrs with no major problems so far. I just went to put the clothes in the dryer because it had stopped, and it was still full of water and in the middle of the rinse cycle. I tried to turn the knob and shut/open the top to make it drain but ended up having to drain manually. It will fill with water but as soon as the cycle starts it makes a weird grinding sound and stops- maybe the motor? We also noticed a slight burning smell. We unplugged it for now...what do we do??? Shouldn't a washer last longer than this?!
  • 62 Answers
It is usually a coupler, look under to see if black shavings
Posted on Oct 20, 2008
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
Kenmore 70 Series Top Loading Washer Leaks
If this is a Kenmore TOP LOADER, you need to remove the exterior cabinet in order to access the washer interior and sufficiently inspect to determine where your leak may be coming from. This is much easier than it sounds. The following link explains how:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
In the majority of cases with a top loader, the water pump begins to leak. These pumps are not serviceable and require replacing if damaged. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Follow the tips in the link provided and make sure you inspect all hoses and tub seals as well. This is a very simple repair that you can perform without the assistance of a repairman. The average cost of a pump is about $35.
If you have any questions, please post back with your MODEL NUMBER (located along the wash tub rim under the lid), so I can determine what washer configuration you have. I hope you find this information helpful.
Apr 22, 2010 | Kenmore 22422 Top Load Washer
My maytag mav7700aww washinging machine wont spin the cloths very good replaced the belt could it be my water pump or what
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Dec 22, 2009 | Maytag Atlantis MAV6000 Top Load Washer
The washer (Kenmore Top Loader Model# 24642300)
It most likely is the coupler. It is located between the motor and the transmission. It is an easy repair and only costs around 20 dollars. To change it out simply unplug the washer and tip it back so you can work under it. The first thing you will see is the pump. Take off the two clamps with a flat head screw driver and move it to the side. Do not take off the hoses unless you want water everywhere. Next you will see the motor. The motor is held up by two clamps. The clamps have 2 screws in each one. Remove the screws and with your flat head pop off the clamps. Make sure you hold the motor cause when you take off that first clamp the motor will drop. The motor coupling will come off with it. Put your new one on, (it only goes on one way) and put everything back together again. You will be up and running good as new in no time again. Let me know if you have any other questions and let me know if this was helpful. Good luck and glad to help.
Jan 17, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Machine went dead with clothes and water in it
with putty knife press in along front edge between top and front about 2-3 ins from outer edges on release clips top will lift up suspect bad lock assembly
Jul 04, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22422 Top Load Washer Logo
188 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
